How do I maintain quality in close up photo
Discussion in 'Photography Beginners' Forum' started by jkamra2, Feb 14, 2007.
  1. jkamra2
    jkamra2 TPF Noob!
    Feb 14, 2007
    4
    Thanks for any help in advance!
    I am trying to take some product shots for a web site. They are close ups of jars of mustard. I frame the shot in my camera (Konica Minolta DiMage Z10) and take the photo. I then open it in Photoshop and at it's normal size, it looks fine (about 5 inches wide by 6 inches tall). But I need to adjust the size to make it 1.68 wide in inches to fit in the web site. I keep the proportions locked.
    When I reduce the size, the text that is on the mustard becomes blurry and unreadable.
    What should I be doing to make the image quality of the photo clear and readable?
    The camera? Different print size? What can I do to make it better?
    Thanks for the help!
  2. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    That sounds way too small to be able to read. Computer screens are usually around 72 pixels per inch...which doesn't give you a lot of pixels at 1.68 inches, to read a label on a photo of a jar.
  3. theusher
    theusher TPF Noob!
    Jan 17, 2007
    250
    Nowhere
    You can try Bicubic sharpener when resizing, but I think making it that small you are likely to lose already tiny lettering? If you posted examples of your problem people might be able to better help you. Also make sure when you size down to whatever you need, you use 72dpi.
  4. jkamra2
    jkamra2 TPF Noob!
    Feb 14, 2007
    4
    I am changing the image size, but I keep the resolution at 72 dpi. I'm not sure if that matters.
  5. jkamra2
    jkamra2 TPF Noob!
    Feb 14, 2007
    4
    How do I insert a picture into the forum?
    I see the "Inset Image" button, but then it asks for the URL, but it is on my computers desktop.
  6. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    Click here
  7. jkamra2
    jkamra2 TPF Noob!
    Feb 14, 2007
    4
    How much does the camera itself influence the photo?
    This current camera is a few years old. I don't know the size of the sensor. The camera says its a 3.2 megapixel and by the lens it says 36-290mm 1:3.2-3.4 (Equiv. 135)
    How much of an effect on the ability to get a better close up shot would a better camera have?
  8. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    For a small image on the internet...that camera should be fine. As long as it can focus close enough to get the detail that you need. Does your camera have a macro mode (usually a flower icon)? If so, I'd use that.
