How do I take portraits with dark edges?
Discussion in 'Photography Beginners' Forum' started by hosh, Mar 2, 2008.
  1. hosh
    hosh TPF Noob!
    Jan 23, 2008
    7
    Alaska
    I cannot for the life of me figure out how to do this. Is it with a lens hood? Is it done in photoshop (I'll be so disappointed if it is!)?? Help me please!
    Here's an example of what I would like the portrait edges to look like:
    [​IMG]
  2. GeorgeUK
    GeorgeUK TPF Noob!
    Dec 26, 2007
    454
    London
    Yes it can be done in Photoshop (at least that's how I do mine).
    Filter>Distort>Lens Correction
    Apply the vignette through that.
    HTH :)
  3. hosh
    hosh TPF Noob!
    Jan 23, 2008
    7
    Alaska
    Looks like I need a new version of Photoshop- I don't have a Lens Correct option. Any other suggestions?
  4. GeorgeUK
    GeorgeUK TPF Noob!
    Dec 26, 2007
    454
    London
    I am using CS2.
  5. hosh
    hosh TPF Noob!
    Jan 23, 2008
    7
    Alaska
    Well, your first suggestion got me digging in my Photoshop (I have Photoshop Elements-completely lame, I know), and I found a filter under "render" called "lighting effect" that does the trick very nicely. So thanks for your help pointing me in the right direction!
  6. GeorgeUK
    GeorgeUK TPF Noob!
    Dec 26, 2007
    454
    London
    No probs. Hope to see some examples in the gallery section soon. :thumbup:
  7. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Here is how to do it in a way which gives you complete control.
    - Create a new layer
    - Select the Elliptical Marquee tool
    - in the Feather option box at the top put in around 120 - 130 px
    - with the page zoomed out a little, click outside the top left corner of the photo and drag it across the image to outside the bottom right of the photo
    - you now have an elliptical shape but first we need to invert the selection, so go to select and inverse.
    - now fill the selection with black and deselect
    - Adjust the opacity of the layer to suit your image, done.
    The advantage of learning this way is that you can create any kind of vignette to suit any image, you can make the feathering harder or softer, change the darkness and shape of the vignette.... if you like you can also play with the layer styles and give it a more burnt in look.
    enjoy.
  8. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    Completely lame? Followed by an admission that you don't know how to use it!
  9. Lakewood Photography
    Lakewood Photography TPF Noob!
    Jan 20, 2008
    26
    Upstate South Carolina
    Thanks Arch!
  10. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    if you didn't want to use photoshop, and do this while shooting, get a couple strobes.
    point one at your background with a grid to narrow the beam, and set up side or top lighting for your subject with one more strobe. i'd try a 2 or 3:1 ratio between the lights, the higher power going to the bg light.
    just a thought.
  11. brileyphotog
    brileyphotog TPF Noob!
    Feb 21, 2008
    272
    Michigan
    You can do it "manually" by stacking a bunch of filters on top of each other. Or by putting dSLR format (like the Nikon DX) lenses on a full frame camera.
  12. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    Your example above was definitely done in photoshop.
    Notice how the vignetting (what the dark edges are called) is in even straight bars down the side of the image. You can end up with that look if you're not careful. Follow the procedure above, but then play around with a layer mask making it darker and lighter in areas to make it look less uniform.
    Also, I like to set the layer style to Multiply when doing vignetting.
how do you take pictures with dark edges
how to get dark edges
how to take a picture in the dark
how to take a picture with darker edges
how to take dark photos
how to take photos with darker edges
how to take picture with dark edges
how to take pictures with dark edges
photography dark edges
portrait photography black edges
