How do i tell if my camrea is soft???
Discussion in 'Photography Beginners' Forum' started by Jxay, Aug 6, 2008.
  1. Jxay
    Jxay TPF Noob!
    Jul 15, 2008
    23
    Orlando, FL
    I've been messing around with my camera for about a month now and a lot of times it's a little soft. I would like to know if there's a way or a good test to indicate rather or not the camera or lens need calibrating?
    Thanks
  2. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    If you're shooting in RAW, it will always be soft.
    If you give more info, we might be able to figure out the problem.
  3. Jxay
    Jxay TPF Noob!
    Jul 15, 2008
    23
    Orlando, FL
    Well i'm not sure if it is or not. Or maybe i'm just paranoid. I'll take a stationary shot of some letterings ... say a calendar about 10 feet away with a 50mm lens and when i zoom in at 100% it's not the sharp as a tack.
  4. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    What camera and what are you using for f-stop?
  5. Jxay
    Jxay TPF Noob!
    Jul 15, 2008
    23
    Orlando, FL
    xsi f/6 iso200 and 1/100 s.s.
  6. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    SO are you shooting in RAW or not??
  7. Jxay
    Jxay TPF Noob!
    Jul 15, 2008
    23
    Orlando, FL
    No, I'm not shooting raw. Why is raw always soft?
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    It doesn't have sharpening applied to it like the JPGs processed in-camera do. You have to adjust the sharpening when you convert.
  9. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    ^^^ Most cameras will be soft even regardless of JPEG vs. RAW. Granted, if you crank up the sharpness this won't be as noticable, but most cameras do not have sharpness turned up by default, and it's generally ill advised to do so.
    What the hell are you talking about, manaheim?! Explain yourself!
    1. Softness is caused by a physical amti-aliasing filter placed over the sensor that "blurs" the light coming into it somewhat to smooth out the colors on the sensor. Otherwise you would have stepping and moire effects. Some cameras have softer filters than others.
    2. You can crank up the in-camera sharpening to counteract this, but it's best to do this post-processing where you can see the results on a (hopefully) far better screen than on the back of your camera. It's also relatively easy to sharpen a soft image, but nearly impossible to repair the damage caused by over-sharpening.
  10. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    Nobody really stated yet that at 100%, if im not mistaken, always soft...
  11. manaheim
    Sep 2, 2005
    14,394
    3,262
    Oh, btw... if you're concerned your camera isn't working properly you can take it to an authorized service place and have them check it. I've also heard of focusing charts you can use to check but I have no experience with them.
