How do you place in Photoshop without loosing PPI?
Discussion in 'Photography Beginners' Forum' started by BoxPhotographer, Jan 24, 2010.
  1. BoxPhotographer
    BoxPhotographer TPF Noob!
    Jun 23, 2009
    101
    Ontario, Canada
    Topic - I'm placing a photo in photoshop on a new file to make a poster. I checked the size in the original file, and it was 13x8 and the actual pixels of the faces looked fine but then when I placed the file, I lost PPI and faces became pixelated. I did not drag it larger than it was meant to be. I actually made the dragged the photo to make it smaller to fit the frame. How do I avoid loosing PPI?
  2. Noonz
    Noonz TPF Noob!
    Jan 23, 2010
    169
    Sydney, Australia
    You don't lose PPI. Because the image is large, photoshop automatically adjusts it to fit the screen, therefore (in some cases) it becomes pixelated. If you click the hand tool and select 'actual pixels' in PS, i'm pretty sure the image will not be pixelated.
    If this is not what you're talking about, then i have no idea.
    Hope it helps.
  3. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    PPI? You mean DPI right?
    Dots per inch - Wikipedia, the free encyclopedia
    what is your poster template size? If its like 11-17 make sure your PS document is set to be at least 300DPI, if your going huge like a 24x36 U have made my template .25 scale at 400DPI resolution. Please give more info on how you setting up your PS document. Also you just dragging the pic into your art-board? or are you actually hitting file>place then browsing for your pic that you want placed in your properly set up document? Please more info...
  4. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    I zoomed in, and the faces look different compared to the full sized image.
  5. Noonz
    Noonz TPF Noob!
    Jan 23, 2010
    169
    Sydney, Australia
    No not really.
    Pixel density - Wikipedia, the free encyclopedia
  6. Noonz
    Noonz TPF Noob!
    Jan 23, 2010
    169
    Sydney, Australia
    That should only happen if you zoom in more than 100% other than that, i have no idea.
  7. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    Hmmm... PPI? I am a professional printer / graphic designer and I have never since 1998 heard the term PPI tossed around, let me pull out my PS bible and also class room in a book on CS4 I feel like i am a step behind you all...
  8. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    Box,
    what's your template setup? I can help I do this for a living...
  9. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    The poster is 8.5 by 11in, not sure how I can find my DPI setting. I'm hitting file then place.
  10. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    sounds like an issue with your original document not being setup properly. Please try this in PS
    If you are going to print posters at your local kinko's etc. this is how I would set up my document.
    1. When you open PS click file > New
    2. then set specs to 8.5" x 11" inches, Resolution 300, Color CMYK 8bit background contents N/A (don't matter)
    3. Click file > Place then brows for your image, place and hit enter.
    When viewing at 100% scale your image should be tack sharp.
    Does this help?
  11. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    Thanks, it was the resolution the I had wrong.
  12. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    COOL! Glad it worked out for you, please ask away when it comes to the "SHOP" Adobe I do know! LOL
how to place image photoshop full size
image loses quality when placed in photoshop
images are pixelated in photoshop
photoshop place full size
photoshop place image actual size
photoshop place image full size
photoshop place original size
photoshop placed image pixelated
when i place an image in photoshop it is pixelated
why is placed image get pixelated in photoshop
