How do you save your images?
Discussion in 'Digital Discussion & Q&A' started by domromer, Nov 19, 2007.
  1. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    I shoot everything at jpeg. I was told everytime you open and close a jpegs it degrades a litle bit more. How many times can you look at a jpeg before you start to notice it degrading?
    Also do you save your files as Jpegs or tiffs. I've got a digital arts teacher who says we should save everything as tiffs. If I did that I would need three more hard drives. What are you guys doing?
  2. BAB
    BAB TPF Noob!
    Dec 28, 2006
    156
    Phoenix,AZ
    Yes you are correct and for that reason it is best not to save as a JPEG. Rather save a master as a TIFF or other non compression format. If you need a JPEG for e-mailing or web, do a save as from your master.
  3. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    How much can you open until you begin noticing degridation?
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    opening and closing are different than saving something.
    for example, you open a file , rotate it and then save the rotation, which is a change. At that time the file re-arranges itself and re-compresses itself which over time is degrading.
    I use only raw files, change them to a TIff file if i am going to use it; and keep 4 copies of every file; the orginal and 3 back up copies. External Hard Drives are very cheap these days.
  5. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    So If i'm just opening them in preview then nothing happens? I actually need to make a change and save it and they will be compressed again? Am i getting that right?
  6. fido dog
    fido dog TPF Noob!
    Nov 14, 2006
    143
    That's my understanding.
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yeah, it only compresses when you actually save it.
    I don't think most people are going to save it enough times to see a change though (maybe I'm wrong, but I've never noticed any quality loss).
    I keep all of my RAWs and process the ones I like into JPEGs. I used to use TIFFs, but like you said - I saw that it was going to use all of my disk space very fast.
  8. wildmaven
    wildmaven TPF Noob!
    Aug 3, 2007
    985
    Picking up dog poops
    I save all images which I will be using for sale as TIFFs. Other images get saved as JPGs. You never know when a customer is going to come in and ask if you can make a print larger than what you have for sale, and with the TIFF, you have a better chance.
  9. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    How does a tiff allow you to print a larger image than a jpg? It's just an uncompressed version of the jpg. Still maintains the same dimensions.
    maybe I'm missing something.
  10. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    Only saving a jpg impacts quaility. And this is marginal. I would consider always making a copy of a jpeg to work on. Leaving your originals as is OR at least do a "save as" which would be the same thing.
  11. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Check out the thread on jpeg compression that was recently posted. Youll see the true effects of JPEG compression. I see no reason to ever save as a jpeg unless your emailing the photo to someone. Also why would you shoot in jpeg if RAW is an option, makes no sense.
  12. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    File size. I don't have the money for multiple external hard drives.
