How do you shoot a flower?
Overread
hmm I recognise this place! And some of you!
Staff member
Supporting Member
UK - England
Website
www.deviantart.com
Like the title says, how do you do it?
I have been experimenting myself and currently this is how I do it:
Use a tripod with focusing rail attached to the camera
Use a macro capable lens set to macro mode - in my case the sigma 70-300mm
Set the camera to mirror lock up mode and timer function (as I don't have a remote shutter release)
Set the camera to manual focusing
Set the camera to aperture priority mode
Use the following settings: f16, ISO 100 (in still weather, with wind 200 or 400 depending on strength of wind).
Use the popup flash with a bit of toilet paper in front (acting as a cheap diffuser) - this is one area that I have already identified as a "weakness" and a proper flash unit with diffuser would be the ideal
Set exposure compensation to -1 (I am usually shooting in bright sunlight)
Set flash exposure modification to -1
So far this is how I am taking my shots, I tend to focus primarily on the centre of the flower.
Now the only alteration to this that I tend to do is to stack 2 or more shots on top of each other, though I have only done this once so far.
So is there anyway that I can modify the above methodology - are there any errors or values that I could change or any other settings I can use to help?
If you want to see examples of my current work on this just check my blog - the last few posts in it are almost all flower taken like this
Thanks
Your shots look very good. Sounds like your doing a good job at setting up. However, wWhen I shoot flowers I like to have a very shallow DOF. Ill use my 50mm and set it to 1.8 or my 70 to 200 and set it to 2.8. But that is just to get the look I like with just a part of the flower in focus. I find a shallow dof gives the shot more interest whereas something around f16 is just straight forward representation of the flower but that is just what I like.
To answer your question though your doing everything fine. There is no right way to shoot a flower so dont get tunnel vision, change everything. Try a very slow shutter in the wind the movment of the flower against a static background may look very nic. Take a shot of a dead dandilion in the wind as all its seed blow away...etc.
Hmmm, well when I shoot flowers I try and keep the process 100% organic or as organic as possible. Turning it into a mechanical operation just isn't for me. To me the flower is art already and my primary roll is to enjoy it. If I can somehow share that enjoyment with others through photography - hey that'd be cool. So I look at the flower. What's it saying? It IS an "expression" after all. Do I understand it's expression? Or is it just another flower to me? If I do then I try to figure out why I understood it and what I understood. Was it because it was new in the world, serving a purpose, survived in the face of chaotic diversity, was a significant part of a group, or lonely and forlorn, etc.? Probably most of that is projection but all things are indeed relative. The next step is to figure out why I came to those conclusions or had those thoughts. What about the environment or setting made me think those things? Was it the light, the other plants around it, it's condition, etc.? Then the final question comes:
Can I capture one or more of those aspects given the equipment I have?
If I can can answer any of the questions in the first part and I can answer yes or maybe to the question in the second part, I take the pic. Usually it's a series of variations on angle, proximity, and DOF. Otherwise I suck in the beauty and move along. Sometimes I find that my camera saw something cooler than I did or a completely different "expression" and I'm happy for those when they happen - I can enjoy the flower twice or see it in a different light (pun intended). ;) This was one such:
I would stop thinking so hard about the process of it. Knowing your equipment well and what works (or not) helps allot. That's mostly practice tho me thinks.
Thanks
I liked this one allot:
Link to Overread's Blog Shroom Photo.​
The 1st image (pink wet flowers) is also good.
thanks for the compliments Bifurcator!
And thanks for the advice all - I guess at the moment I am still very new to this and I want to make certain that I am at least getting the technical side of my photography well under control. After that I am now starting to get my photographers eye in to see the shots and be a little more creative with my shooting. Kind of means making rules and then breaking them ;)
Reading through peoples comments it seems as if I do have the technical side under control - time for the artistic.
Oh and I don't see photography as a set of rules so much, but I tend to shoot mostly wildlife - where I tend to not have any time to setup a shot and take it, much more a case of shooting and hoping as they move around so much - recently I started with the macro and with flowers and I find it relaxing to be able to take time to get a shot and to set it up right, rather than just shoot and hope
Wildlife, ah so you can work the AF/AE Tracking well. That works well with flowers too! Set it on the spot of interest, position yourself, snap, move and retain the track point, snap, etc. Setting a fixed focus point cursor somewhere with the tilt-wheel-thingy is another good way too. Especially the tracking tho.. Really frees you up for adjusting your proximity and angle. Makes the process more fluid and fun. And remember... It's digital film so don't be afraid to shoot way more than you need and kill the others later... It's like free film... \(a.a)/ YAY!
AF tracking I get - but back-up and explaint AE please?
(remember new person here - still ;))
Ah, sorry, some (most?) cameras will allow you to set the exposure metering to center around and follow that little tracking cursor.
AE = Auto Exposure (and also applies to the shutter or aperture automation while the camera is in either of the priority modes; S or A.)
Ahh I think I get you - though I tend to be an apature priority person and let the camera auto set the exposure based on changing shutter speed.
And yes Shooting like a madman I do do - though I am trying to limit it a bit at the moment, focusing on quality and making shots count at the moment - also helps with storage space as everything is in RAW these days (that is PC storage I have a good 12GB of camera memory cards :))
I think also with my sigma I have become tripod attached (seriously the sigma lens should come with a tripod I feel at times ;)) But its something to keep in mind for the future (very near now) proper macro lens
Yup, that's it. Set it on Aperture priority, select a metering style that follows the cursor, turn on tracking and it should weight the shutter selection on wherever your tracking cursor goes. Anyway, that's just one way. There's lots. :D
Ah, I see you suffer from keepers syndrome. I used to too but after filling up several terabyte raid arrays I had to force myself to trash any files I didn't think warranted my time to edit. Now when I do do the mad-man shooting style, I probably only keep 10% and I trash ALL jpegs as well. Since doing that everything is SOooo much more manageable! And I can actually find stuff now too! :D
I hear ya on the pod thing! Try a cheapy close-up lens (like a #4 or #3) till you get the money for a "macro lens". You may just like it so much that you skip out on buying the macro lens all together. Get one that fits your 70~300... :D
I primarily shoot flowers and I have the same lens as you so I think I may as well share what I do.
Equipment I use for flowers:
Pentax K100D
Sigma 70-300mm f/4-5.6 APO DG Macro
Settings:
ISO 200
f/11 or f/16
300mm focal length
Manual focus
Handheld
Good first try. Try thinking more about the composition - some are of your shots great and some aren't. I prefer a border of blurred greenery surrounding the subject flower. Take advantage of the shallow DOF to emphasize the flower and use the bokeh to set a gentle tone to the image. I like the second red rose but as you said in your blog, the "specimen is less than ideal".
For flowers I generally don't get too involved, they're large enough that I don't have to get too close (relatively speaking). I generally hand-hold, and select an exposure appropriate to the conditions (wind mainly) with the DoF preview, compose 'til I'm satisfied.
For small stuff, then the tripod, reflectors, flashes and all that other good stuff comes out.
