How does my lighting look?
Discussion in 'Photography Beginners' Forum' started by logan9967, Feb 21, 2008.
  1. logan9967
    logan9967 TPF Noob!
    Jan 28, 2008
    611
    Philadelphia, Pennsylvania
    Please ignore the dust on my sensor, and the bad positioning of the pen. This is a lighting test.
    [​IMG]
    Please be harsh :D
  2. logan9967
    logan9967 TPF Noob!
    Jan 28, 2008
    611
    anyone? i'm wondering if this light setup works. cause it's really easy for me and saves me a lot of moolah. it's only for macro too btw
  3. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Please tell of your setup. The shadow is bugging me.
  4. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    What is the effect you are trying to achieve? This might sound like a smart-butt answer, but if you like it, then it works, right?
    If you are going for the shadow, then that looks fine. If you are wanting a cleaner look, to display the pen better (like for product photography), then use some softer light, and more light sources from more directions.
  5. brileyphotog
    brileyphotog TPF Noob!
    Feb 21, 2008
    272
    Michigan
    Looks fine to me...but I'm with Keith. I don't really know what you're going for here.
  6. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    It depends upon what you are going to light with the set-up.
    The pen, having some highly reflective surfaces, is showing the shortcomings.
    The hard-edged shadow shows that the light is mostly a point source hence the hot-spot on the top front. It is also picking up the texture on the metal - not something you always want with macro.
    And the reflections of light and dark along the whole of the pen - especially around the front end - are rather messy. The important part of this shot is the lettering on the end so you should be working to sculpt it more. To deliniate the embossing.
    You would do better to build a small light tent with tracing paper to soften the light, reduce texture and reduce lighting contrast.
    If you build it right you should not be able to see any reflections on the pen.
    You then use strips of black, white and grey card to put shadows and highlights where you want them.
    This, of course, is a suggestion for the pen.
    Different objects require different lighting solutions determined by what qualities you want to show, what you want to hide, and what each is to be used for.
  7. logan9967
    logan9967 TPF Noob!
    Jan 28, 2008
    611
    :O
    <3
    and yes i guess i should of explained more.
    i was talking about the highlights of it. and if they looked decent and then i was going to do the same for the shadow side
    the light i have is a pretty simple bulb, with almost pure white light, then diffused with paper. I wanted to make sure it's not to harsh right on the object, i'll have to take some pic's with somthing less reflective
    thanks for the help :D
    i'm extremely new to fancy lighting and such, i usually always use natural.
    what i'm trying to ask is if the lighting on the pen is too harsh :p
    if it's good then i will continue sort of with this setup and add it to the other side and keep it at this sort of light for every object i photography sorry for not explaining haha
  8. mky
    mky TPF Noob!
    Sep 29, 2007
    10
    the picture looks fine and i can also say it has something artistic in it
  9. mky
    mky TPF Noob!
    Sep 29, 2007
    10
    what camera are you using?
  10. logan9967
    logan9967 TPF Noob!
    Jan 28, 2008
    611
    * points to signature *
    you can click on my name for my lenses and such as well
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Technically it is properly exposed. Artistically, I think that the light positioning could be better and apparent size of the light could have been larger causing softer shadows.
    Not knowing your goals it is difficult to know if those shadows were your goal or not.
    - focus is good
    - bokeh is good
    - sharpness is good
    - the dust on the sensor bugs me (lol)
    There is not much more to be said.
