How does this photographer achieve such results?
Discussion in 'Beyond the Basics' started by MrEd31, Feb 19, 2004.
  1. MrEd31
    MrEd31 TPF Noob!
    Aug 13, 2003
    32
    I was wondering how this photographer has created such impressive tonality and drama in her photographs. I know that she has used red and orange filters in her photographs, but i've never quite been able to bring such power to a print.
    Does this have to do with the use of a medium format camera or a large format camera?
    Does this have to do with a lot of burning and dodging to polish the image?
    I have trouble understanding or being able to successfully burn or dodge when printing.
    thanx
    http://www.photo.net/photodb/folder?folder_id=299816
  2. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Much of the drama in in her mind's eye; she has quite a knack for composition. Beyond that it's also obvious that she has a lot of skill. And then there is being in the right place at the right time; these are fairly dramatic locations.
    She uses both red/orange filters to increase cloud/sky contrast, and wide angle lenses to create dramatic sweeping views with maximum DOF.
    She is using a Pentax 67 and a 4x5 field camera. Medium and large format can certainly produce wonderful detail and tonality. The large cameras also tend to slow the photographer down; sometimes this results in a more thorough exploration of the subject.
  3. Sharkbait
    Sharkbait TPF Noob!
    Nov 4, 2003
    2,403
    17
    Indianapolis, IN
    Some of em look like IR filters, to me.
  4. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,379
    2,840
    In the mental ward of this forum
    They are all very beautiful. It's wonderful that she can get to these locations and that she knows what she's doing. You gotta tip your hat. :thumbsup:
  5. jack
    jack TPF Noob!
    Jan 16, 2004
    250
    london
    slow shutter-speeds, nicely apertured to give that DOF,
    red / orange filters, and ii'll wager, a grad ND filter.
    - there seems good available-light , as well as great scenery,
    but the light is nicely limited to give these result. excellent choice
    of time of day.
    excellent choice of film too.
    what do you think ?
  6. Kent Frost
    Kent Frost TPF Noob!
    Jan 27, 2004
    572
    21
    Springfield, MO USA
    Well, there's really no such thing as an "IR" filter. Only IR film with different colored filters. In either case, she didn't use IR film here, it was mostly all Kodak Tri-X 320 in a Pentax 6x7.
    Great stuff.
  7. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Lighting is why these photos are so dramatic (obviously she knew how to capture it). Often times you'll see photographers waiting out for the perfect lighting. if they don't get it due to some clouds they go home with out a picture.
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Good point. Patience is a skill many photographers overlook.
  9. MrEd31
    MrEd31 TPF Noob!
    Aug 13, 2003
    32
    Kent Frost,
    There is in fact such a thing as an Infrared filter. R72 filters are for when you want to do true black-and-white infra-red photography. They are extremely dark (much darker than a Red 25A filter), letting only infra-red radiation of 720 nanometers or above reach the infra-red film. Since an R72 is so dark, it usually requires longer exposure times, so we recommend using a tripod in conjunction with this filter. It is very dark in color and prevents the visible spectrum from passing through. A photographer must focus and then put the infrared filter over his lens. The photographer must also make a slight change in the focus, because the filter scews focusing. They are pretty expensive, but very available...
    http://www.freestylephoto.biz/sc_prod.php?cat_id=1904&amp;pid=4322
  10. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    Don't these filters only work with IR film, tho? I think that is the point Kent was making. There is no filter that will pop onto the front of your camera to "make" IR images on just any film.
  11. Face
    Face TPF Noob!
    Aug 13, 2003
    82
    $5 in quarters
    i think besides how she took the picture, part of the greatness of the picture is how she printed. the contrast is really good, with white whites, dark darks, and very good dodging and burning (i'm geussing) to bring the picture together. a great negative doesn't automatically make a great picture.
