How far to push the chemicals?
Discussion in 'The Darkroom' started by laser, May 29, 2004.
  1. laser
    laser TPF Noob!
    May 29, 2004
    UK
    I print a lot in a Fujimoto roller type print processer using RA4 chemistry.
    I usually start off running the dev' bath it at 38 degrees and then notch it up to gradually up to about 42 degrees when the blacks start to go blue.
    Usually when I try and go higher everything starts getting quite muddy.
    Does anyone know any tricks to get some more use out of the chemistry?
    I use Agfa dev and bleach fix, and a mix of water and acetic acid as a stop bath.
    Cheers!
  2. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    When the blacks started going blue I always replaced the developer. This was when I was in school, so I didn't really have to worry about chemical cost though.
  3. laser
    laser TPF Noob!
    May 29, 2004
    UK
    nobody got any tips then?
    Anyone else do there own RA4?
fujimoto
