How important is HCA?
Discussion in 'The Darkroom' started by rob91, Sep 15, 2008.
  1. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    The process that I learned in school, and what I've been using since, is after the fixer 2 min water rinse, 2 min HCA, then a 5 minute water rinse. Is HCA necessary? If not, how would I alter my plan? Thanks.
  2. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,034
    508
    L.A.
    My "bibles" for film developing are Steve Anchell's books, The Darkroom
    Cookbook
    and The Film Developing Cookbook.
    Most fixers are acidic but Steve recommends using an alkaline fixer and he
    states that when using an alkaline fixer no HCA is needed and film wash times
    are also greatly reduced. Photographer's Formulary sells an alkaline fixer
    called TF-4, also available from Freestyle. This is what I use. An alkaline fixer
    is also far less likely to cause pinholes then acid fixers.
    Steve also gives a simple formula for mixing your own alkaline fixer from
    scratch in his books.
    If using an acid fixer, though, you do need to use HCA for archival permanence.
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    are you talking about with film or papers?
    for film and RC papers there is no need for HCA
    for fiber papers it is very helpful for reducing the wash times
  4. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    I'm talking about film. I use Kodak rapid fixer, btw.
  5. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    The risk of pinholes comes with the use of acid stop baths that are not buffered well and with a pH higher than say 4. When the sodium carbonate, in most developers, hits the acid stop carbon dioxide gas is created in the emulsion causing the pinholes.
    Acid fixers are typically lower acid pH around 5.5 and are typically not the cause of pinholes. I suppose it is possible if you plunge the film right out of the developer into the fix it may happen, but the fix will most likely become quickly exhuasted without doing a water rinse prior.
    Also, if you skip the stop bath and go with a water "stop" know it does not actually stop development, so you will need to adjust your development time to account for this.
  6. compur
    Mar 6, 2008
    3,034
    508
    L.A.
    ^ Yes, that's true. I forgot to mention I also use a water stop bath as Anchell recommends, making it it all all non-acid process.
  7. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    compur, do I need a non-alkaline fixer, or were you referring to something else?
  8. compur
    Mar 6, 2008
    3,034
    508
    L.A.
    I use a water bath stop and an alkaline fixer called TF-4.
    That makes the whole process non-acidic since developers are
    also alkaline and water is, of course, neutral.
    It's my belief that this is a very archival way to process and is
    also simpler & faster because no HCA is necessary and wash
    times are reduced when processing this way. There is also
    less chance of "PH shocking" emulsions by going from an alkaline
    developer to an acid stop and fix which can cause reticulation,
    pinholes, etc.
    However, regular acid fixers are much more plentiful and may
    be cheaper too. Most photographers use them and I don't
    mean to say they are doing anything wrong. I just like to
    treat my materials as gently as possible. But, there's nothing
    wrong with using an acid fixer -- just use HCA and wash
    thoroughly when you do if you want your negs and prints to
    last a long time.
    The preceding is purely my opinion and the way I like to do
    things. :)
  9. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
  10. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    There are also neutral fixers, often intended for use with C-41*.
    If you are using a rapid fixer and it has not been overused, you should be OK without HCA for film. You might want to consider switching to a set of water changes (say six, to be on the safe side) with constant agitation for one minute instead of your current wash method.
    Washing fixer out of film is easy. Washing intermediate silver complexes out of the emulsion after incomplete fixing is more of a problem, therefore it is important not to overuse fixer. One way of ensuring complete fixing while staying economical is to use a two-bath fixing process.Most of the fixing is done in the first bath, and the second does very little.
    The first bath may be discarded when the clearing time is double that of fresh fixer. What was the second bath then becomes the first bath, and a fresh second bath is made up.
    As an aside, The Film Developing Cookbook is attributed to Steve Anchell and Bill Troop. Many of the formulae are Bill Troop's. A formula beginning TD or TF is likely to be a Bill Troop formula (TD for Troop developer and TF for Troop fixer, such as TF-4).
    Best,
    Helen
    *Edit: An example is Kodak Flexicolor Fixer, a rapid fixer which has a pH of 6.5 at working strength - ie close to neutral. It is often easier to find such fixers than it is to find TF-4 if you don't want to pay for shipping liquids.
  11. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    That's a regular sodium thiosulphate fixer, with ammonium alum hardener. It has a pH of around 4.5 at working strength - ie it is an acid fixer.
    When I use TF-4 my fixing time is usually one minute in each fixing bath.
    Best,
    Helen
  12. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    Thanks Helen.
    When you say "each fixing bath" are you referring to the two bath process you describe, or two separate fixers?
    Also, something interested I noticed while researching: http://www.usefilm.com/Photo_Forum/13/1012562/
    You're everywhere!
