How is this lighting achieved?
Discussion in 'Beyond the Basics' started by Alerick, Jun 4, 2009.
  1. Alerick
    Alerick TPF Noob!
    May 19, 2009
    25
    Corbis: photography, rights, motion.
    I see alot of photos where the lighting has a dark contrast with lots of detail. How is this achieved? is it in the lighting an camera settings or done post?
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    If I had to guess I would say flash with a fast shutter time and/or small aperature.
  3. Big Mike
    Dec 16, 2003
    33,841
    1,815
    Edmonton
    It has to do with the placement of the lights...most importantly, off camera. It's then a matter of setting your lights & camera to get the exposure you want.
  4. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    It's very, very carefully controlled lighting. Atleast two flashes, and it looks like they're pretty carefully flagged. There's hard light on the subject, but the people holding him up are significantly less lit. He's just being wing lit from both sides, with flags to keep the direct light off the other people.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    One strobe camera right, one camera left. That's it, no tricks.
  6. manaheim
    Sep 2, 2005
    14,394
    3,262
    Hm, the off-cam lighting to the sides hadn't occurred to me. Neat thought.
    Couldn't you get the same effect from dead-on flash and flash dropoff and careful control of aperature and such? (minus the angle, of course)
  7. johnbergsing
    johnbergsing TPF Noob!
    May 2, 2009
    64
    Alabama
    I concur. Looks like the keylight was camera right.
  8. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    5,649
    742
    Woodbridge, Ontario, Canada
    Diffused strobe on Right ... same level as primary guy ... reflector on Left pointing back down on primary guy ?
  9. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    No, it's hard light, look at the shadow on his wristwatch, and if a reflector was used for the other side, it'd be so close, you'd see it in the frame.
  10. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    No. Dead on flash would leave no shadows on the side of his face/body. This shot is a simple two strobe light shot. Nothing tricky about it.
    Here's a shot I did that's somewhat similar except that I added a bit of fill from a third light
    [​IMG]
    and another simple two light shot
    [​IMG]
  11. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    The key here looks like careful control of flash and your manual mode settings on your camera. After you decide on the placement of your lights, You would expose your subject with your Aperture setting and then dial down your shutter speed until you remove most or all of the ambient light in the room.
    At least, that's what I would be trying to do. :)
    If you want to see more on this subject, check out this link. It covers shutter speeds and "key shifting". In particular, the key shifting section around 4:20 in the video begins the discussion on key shifting with your shutter speed and an external flash.
