How is this technique done?
Discussion in 'Photography Beginners' Forum' started by arcooke, Jun 23, 2008.
  1. arcooke
    arcooke TPF Noob!
    Feb 24, 2008
    391
    8
    Plano, TX
    [​IMG]
    What' I'm referring to is how the background appears larger than it actually is (notice how the sun is so large). I'm just wondering if anyone knows the name of this technique and how it is achieved. This was a snapshot from a movie, so I'm not sure if it's something that only high end expensive movie cameras can do.
    Thanks!
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    Long lens... long lenses compress apparent space.
  3. arcooke
    arcooke TPF Noob!
    Feb 24, 2008
    391
    8
    Plano, TX
    Oh, thank you. I'm still very new to all of this.
  4. darkpbstar
    darkpbstar TPF Noob!
    May 13, 2008
    273
    also at different parts of earth's revolution around the sun, it will appear larger, and at different locations at the earth (the same goes for the moon). This is assuming you know how the rotation and revolution works of the bodies of our solar system in relation to our changing seasons. and apparently a larger lense will work too!
  5. dylj
    dylj TPF Noob!
    Apr 30, 2008
    141
    The sun (and the moon) look much bigger when closer to the horizon. It's an optical illusion.
  6. EW1066
    EW1066 TPF Noob!
    Apr 4, 2008
    185
    4
    Santa Fe, Texas
    A long lense can apear to compress space but it cannot change relative size. What you are seeing is the sun's aparent size being magnified by the atmosphere as it sets. When the sun is low on the horizon, the light has to pass through more of the atmosphere before you see it and the air acts as a lense magnifying the image of the sun that you see. It is the exact same effect that you see when the moon rises and looks enormous on the horizon. As either body goes higher in the sky, its light passes through less atmosphere and the effect is reduced.
    Vince
  7. arcooke
    arcooke TPF Noob!
    Feb 24, 2008
    391
    8
    Plano, TX
    Ah-ha. I found a perfect example image.
    Description:
    "the top image shows the laundry hanging, but by moving away from the subject and then zooming-in so that it still fits within the same area in the picture results in the background becoming nearer due to the field of view getting narrow"
    [​IMG]
  8. dklod
    dklod TPF Noob!
    Sep 24, 2007
    344
    In a tent outside the gates of hell
    Im sure the atmosphere does strange things to the sun and the moon, but to me in regards to the original image is that both the car and obviously the sun are in the distance and the camera is zoomed in. The car looks normal size even at say 300mm but the sun on the other hand, because its so far away, looks even bigger.
  9. ksm
    ksm TPF Noob!
    Mar 17, 2008
    93
    I agree
    Granted the sun will look bigger because of its position on the horizon but as far as the image result it is because of the use of a long lens. Try it out and take a photograph of a cityscape for example. If you use a wide lens everything will show up at a relative "normal" scale to each other. If you use a longer lens the objects that are further away will be "drawn closer" to the forefront objects and and they will look bigger in relative size.
    Hope that makes sense
  10. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Ok, wow, that's completely tapped. Learn something new every day on this forum.
  11. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    See this sun technique in a lot of movies.
    Is that just a random car or someone you know? You in Cali?
