how to achieve color tints?
Discussion in 'Photography Beginners' Forum' started by jgr025, Aug 9, 2009.
  1. jgr025
    jgr025 TPF Noob!
    Aug 9, 2009
    New to the forum, new to photography in general. Appreciate any tips or hints you are willing to share!!
    I'm wondering how photographers achieve certain color tints or washes in their pics. Is this done by some kind of white balance adjustment or is it done through photoshop? Or a combination?
    Thinking of pics like these, for example - how are they done?
    http://4.media.tumblr.com/D9QEnuQFoprsev5oHcMWssz1o1_500.jpg
    blue/green tint
    http://8.media.tumblr.com/D9QEnuQFonm3sqxzAHo5ugfxo1_500.jpg magenta/blue tint
    (sorry don't know the credit for these pics)
    I could probably get a regular photo to look like this in photoshop if I tried hard enough, but I like the idea of doing it with the camera instead. Just wondering if this is a common, easy technique, as I see photos like this all the time.
    Thanks again in advance.
    - Jon
  2. DScience
    DScience No longer a newbie, moving up!
    Apr 12, 2009
    1,513
    122
    Denver, CO
    that's all PP bro. BTW, I believe it's against forum policy to post pics that aren't yours. Links are okay however.
  3. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    It doesn't have to be done with PP. You can easily create interesting tints in the image by changing the white balance on the camera and gelling a flash. You could, say, set the WB to a bit plusgreen, and then gel your flash minusgreen (magenta), to achieve a green tint or colour cast wherever the light from the flash isn't. (The magenta on the flash and green added in the camera cancel each other to produce white.)
    A more common application of colour key shifting is setting a tungsten white balance and gelling the flash CTO. That creates a pretty cool effect, since if you add another CTO to flash you'll get warm and cold tones playing off each other in the same image.
    For the first image, it's possible that a greenish WB was set, and a flash was gelled magenta and placed outside the window. For the second, it's possible that a flash was placed to the left of the frame, next to the bed pointed at the subject (zoomed out or through a modifier to add more spill), gelled green, and a magenta WB added in the camera.
    All that, of course, would be after correcting for ambient light, both in camera and with gels, and then working from there. Start on a level playing field, so to speak.
    And yes, you should link to the images, not post them directly.
  4. Stosh
    Stosh TPF Noob!
    Jul 18, 2009
    203
    Lancaster, PA
    Just wanted to agree with musicaleCA and possibly add a few things.
    As you can see both of these images have places that are white and places that are tinted in the same scene. Your eyes correct for this and you don't notice the color change when looking in person.
    To create this you need 2 different sources of light. Any 2 with different colors will do. Daylight, incandescent light, fluorescent light, neon light, flashes, moonlight, etc. You have to be careful to balance them out the way you want them so one does or doesn't overpower the other. Then you adjust your white point in post processing. You can experiment by choosing different parts of your image for the white balance point. Every different place in your image will give a slightly different color cast to the rest of the image.
  5. DScience
    Apr 12, 2009
    1,513
    122
    Denver, CO
    these pics are pp for sure. you cant get this look from lighting alone.
  6. KmH
    Apr 9, 2009
    40,548
    5,543
    Iowa
    Yes you believe correctly. It's all in the forums Rules & Regs that few new members bother to read.
  7. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    I think people would read the Rules & Regs if the Rules & Regs were easier to find...like as a link in the grey bar that has "Home", "Forum", "Active Topics", etc...I don't think a lot of people think of looking for the Rules & Regs in the Quick Links drop down.
  8. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    And what makes you so sure of that? Anyone can say anything. I'm inclined to believe that the first was done with colour key shifting on-location because of the desaturation of the green tint in the blinds (where the corrected light would have been spilling through).
  9. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Why not?
    If you had two different lights, you would get this look by default unless you corrected for it.
  10. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I think the first one is way simpler than you think.
    Fluorescent lights inside the room (which are known to cause a greenish cast), daylight coming from the window.
    White balance on daylight.
    No PP required.
    EDIT
    The second one could easily be the same kind of situation, but it looks more like PP to me.
    You could do it just by using different light sources though.
  11. jgr025
    jgr025 TPF Noob!
    Aug 9, 2009
    wow, you guys are fast!! Great community here, thanks for all the replies. Much appreciated.
    Apologies for the embedded pics, just wanted to save you guys the hassle of having extra clicks to see what I was talking about :)
    I'll fix it now.
    So I guess basically what you are saying is if I -can- control the light with gels or color temp and white balance, try it in camera. If not... then the same or close to it can be done with PP. Makes sense.
    If I do any tests I'll post them in this thread and see how it goes. Again all new to this so I appreciate the advice!!
    - jon
  12. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yes.
    You need two lights of differing color temperature. Set your white balance to one of them, let the other one be 'off'.
