How to achieve this look?
Discussion in 'Beyond the Basics' started by bar-elo, May 14, 2009.
  1. bar-elo
    bar-elo TPF Noob!
    Feb 22, 2008
    7
    Hi, does anyone know how to achieve this "look" on pictures.
    Creating the background completely out of focus and in "motion". Or is this just a Photoshop "Gaussian Blur" trick?
    Thanks in advance.
    http://lanternaphotography.files.wordpress.com/2009/05/baby-106-copy.jpg?w=397&h=650
    http://lanternaphotography.files.wordpress.com/2009/04/img_3203.jpg?w=761&h=507
    http://lanternaphotography.files.wordpress.com/2009/04/baby-77.jpg?w=546&h=819
    http://lanternaphotography.files.wordpress.com/2009/04/estefy-271.jpg?w=719&h=479
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Very simple. The effect is the result of a 'shallow Depth of Field' (DOF).
    DOF is controlled by a few factors;
    The main factor is the aperture of the lens, a larger aperture (smaller F number) will give you a more shallow DOF.
    The focal length is a factor, the longer the focal length (you might say zoom), the more shallow the DOF.
    The closer the subject is the the camera, the more shallow the DOF can be.
    The size of the recording medium (film or digital sensor) is a factor. A larger sensor can give you more shallow DOF than a smaller one. This is why it's hard to get this effect with a typical compact digital camera...they have very small sensors.
  3. bar-elo
    bar-elo TPF Noob!
    Feb 22, 2008
    7
    Thanks for the info, it was very useful.
    I wasnÂ’t aware that the longer the focal length the more DOF you could achieve. Do you think that kind of pictures could be taken with a 55mm lens? Or do I need a telephoto?
  4. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    It can be done at just about any focal length really. The aperture setting has a lot to do with it. Get the widest aperture you can. This sample was shot at f/2.8 and 70mm.
    [​IMG]
    This was shot at f/4 and 60mm.
    [​IMG]
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Technically, the longer the focal length, the LESS DOF you can achieve...but the background can get more out of focus ;)
    The problem with that, is that with a longer lens, you may have to back up to frame your shot, and the farther back you get, the more DOF you get...so it's a trade off.
    As mentioned, the main factor is the aperture of the lens.
  6. bar-elo
    bar-elo TPF Noob!
    Feb 22, 2008
    7
    That’s what I meant, sorry, less DOF.
    I usually take pictures with high f/stop so everything is "focused" but now I’m going to go the other way around, looks interesting. Thanks for the help people!
  7. Mtalicarox
    Mtalicarox TPF Noob!
    May 7, 2009
    188
    Mike - You really know your stuff. This is FANTASTIC. I was reading my manual for my DSLR (I'm just getting in to photography that is greater than a point + shoot) and I was reading about this in the manual and the way they have it written is confusing as well. The explanation you gave here is perfect, easy to understand. I actually printed out this post you made and put it onto a flashcard to keep with my camera equipment as a reminder of how to do it if I get confused.
    I have 1 other question - I have a lense that's got a "Macro" mode(it's a switch on the side next to the MF/AF button). It is an older model Canon lens, purchased in the 90's by my dad for his film SLR (we now both have DSLR's) but the lens is compatible and works fine. I have played around with the aperature setting to create some cool pictures, I don't have the actual lens model with me (I'm at work now) but I can get it when I get home - but my question is do you know if switching the button to "Macro" will automatically set the aperature, and DOF for me?
    I understand if this is a stupid question to ask before giving you the lens model and everything like that - just figured I would ask. I'll post the lens model when I get home.
  8. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I believe the switch is for this purpose.
    Quote from Wikipedia
    "Focusing distance range limiter switch: This switch is found on most longer focal length lenses, and macro lenses. It is used for limiting the focusing distance range of the lens, when using it in autofocus mode. Most lenses have two settings, these are usually full focus range (from minimum focus distance to infinity), and distant focus range (from half way point of focus range to infinity). Other lenses have three settings, with the additional setting usually being near focus range (from minimum focus distance to half way point of focus range). The reason for this feature is to shorten the autofocus time for the lens. Longer focal length lenses, and macro lenses, have a longer travel distance for the focusing mechanism inside the lens. So when the photographer knows they will not need a certain part of the focus distance range, limiting it will help shorten the autofocus time, and possibly prevent "focus hunting"."
  9. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Did you shoot these photos? If not who did? Did they give you permission to post these with out credit?
    Love & Bass
  10. Mtalicarox
    May 7, 2009
    188
    Unless they are your pictures I seem to think it's not your problem? And if they are you should watermark them.
  11. ~Stella~
    ~Stella~ TPF Noob!
    Sep 2, 2007
    968
    I believe it's forum policy to post only photos you have legal rights to. That said, you can post links to anyone's images for discussion purposes.
  12. Mtalicarox
    May 7, 2009
    188
    I think you're correct but is it up to every member to check on that? Or is it up to admins and moderators?
