How to fix forbidden folders?
Discussion in 'Off Topic Chat' started by UUilliam, Aug 22, 2009.
  1. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    i get
    Forbidden
    You don't have permission to access /littlecuties/ on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    how do i remove this?
    (my website btw)
    I want it to display the directory
    it only works if i make it a index.html...
    I am using godaddy (domain + free hosting, with domain.)
  2. boogschd
    boogschd TPF Noob!
    Mar 19, 2009
    606
    ph
    404's mean that the page doesnt exist i think
    check your links?
  3. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    GoDaddy hosting? *shudder* Best contact them and ask what's up. My uneducated guess is that for some reason, your read-write permissions on the server for that folder are revoked, or damaged, or whatever. If it's a Unix server, it should be a simple permissions fix; if it's Windows...er...pray? :meh:
  4. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    Chances are you'll need to set up a .htaccess file which allows the directory to be read without an index file.
    Try creating or modifying a file in that directory called .htaccess and add the following directive:
    Or if that doesn't work, try:
    Save the file and try again. You will also need all-read privs on the directory that you're trying to link to.
    As to why your error document is giving you a 404, can't help you there.
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Thanks Ruffus, Worked for me :)
    (Options +Indexes)
