How to get rid of green glows...?
Discussion in 'Beyond the Basics' started by msvg, Jul 19, 2009.
  1. msvg
    msvg TPF Noob!
    Dec 19, 2006
    26
    Toronto, Canada
    I was wondering if any of you have the same problem I do. Sometimes when I take night photography, I get this green glow show up.
    Ex:
    [​IMG]
    Is there anyway to avoid that?
  2. shmne
    shmne No longer a newbie, moving up!
    Jun 3, 2009
    641
    83
    Florida
    That looks to be a lens flare, there are different routes to try and I'd start with the cheapest being a simple UV filter. If that doesn't work you can always buy a lens hood
  3. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    That should be "the cheapest being to remove the UV filter".
    Adding a filter of any kind will always increase flare problems. A lens hood can help when the light source causing the flare in outside of the frame. In this case, though, the "evil" light source is in the picture so a hood wouldn't be of any help.
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    If you have a filter in front of your lens, remove it. That should reduce the amount of the lens flare.
    Lenses are not create equal, some of them has better control on lens flare than the others.
    As for the lens hood, it's a little tough in this situation being the light source was in the flame. So the lens flare will shows up with or without hood.
  5. shmne
    Jun 3, 2009
    641
    83
    Florida
    I'll be honest I've been told many times that if there is lens flare that I should remove my filter, but sometimes putting on a UV or ND filter has helped.
    I wasn't really thinking though about the hood =\ I should have known better D=
  6. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    Looks like Casper the Friendly Ghost to me. :lmao:
  7. KmH
    Apr 9, 2009
    40,732
    5,587
    Iowa
    You might try a different white balance setting since you're getting a 'green glow' pretty much everywhere, in addition to the lens flare.
  8. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    QFT. Adding some magenta tint will likely help matters.
  9. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    Yea I think he means the white balance is off. If you sot in RAW it would be easier to fix in PP. Try to play around with it in lightroom.
  10. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Green is usually indicative of flourescent light, which the city lights are showing. So you may try setting it for flourescent and, depending on how many settings you have in your camera play with the others. The other two lower lights are showing up like incandescents.
  11. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Sheesh, people. :lol:
    I actually thought green was tungsten... I think flourescants are usually more blue, but whatever the case...
    Rule #1 in Night Photography - NO EXCEPTIONS - shoot RAW and change color balancing in post processing.
    Seriously... NO exceptions. You shoot RAW or you go home.
    The problem with non-RAW is many-fold...
    1. Whatever picture you take at night is going to get PUMMELED with whatever the dominant light of choice is, and there's essentially no way to really fix it.
    2. There tends to be a variety of colors of light and the camera gets massively confused OR if you pick one particular white balance it may skew the image against other light sources.
    I should put up the image I took years back that forced me to learn this, but here is a recent example of one of my night-time pictures... the first time I took this I took it in JPEG and it was horrific and unfixable.
    (I hope you don't mind my posting a pic of mine in your thread)
    [​IMG]
    I'm a night photography addict, so let me know if you have any questions. Happy to help.
  12. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Start with properly white balancing. Use other avenues in PS after the fact if necessary.
