How to hold 2 cameras?
Discussion in 'Photographic Discussions' started by keith204, Jan 10, 2008.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    When you go out with 2 cameras, and need them both readily accessible, how do you hold them? I can't seem to get it right, comfortably...
    Cam 1: 40D/grip/70-200 2.8
    Cam 2: XT/grip/17-85/Flash
    It seems like a silly question, but I simply can't figure it out!
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    2 neck straps.
  3. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Yip Normally I have one over my shoulder and the other around my neck
  4. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    I worry about the one over my shoulder falling off.. maybe I can get a sticky strap of some sort
  5. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    I like to have one camera on my hand, with a short strap. I wish I had a battery grip so I could attach a hand strap. The other one is either around my neck or around my shoulder with a long strap.
    I have two of the 'TFP' straps which works out well for this because of the way they can unclip. I take out the neck pad part of one strap and clip the short ends together for a wrist/hand strap on the camera. Then I add the neck pad part to the other strap on the other camera, which makes a nice long strap for around my neck & shoulder.
  6. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    Put it over your head and across your chest/back...rather than just over one shoulder.
  7. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    One on a strap... hanging at my side with the strap long enough to cross my chest/back to my opposite shoulder. Another camera on a VERY short strap... just enough to wrap my wrist in.
    Normally shoot with one in hand with the strap wrapped around wrist just in case. When its time to shoot with the other, I let the in-hand camera hang by the short strap from my elbow. Then I reach over and grab the camera at my side and slide/pull it up to my view.
    Hope this makes sense... hard to explain and far easier to do when the cameras are not too big.
  8. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    That's why I like the Up-Strap. The rubber shoulder pad is a little sticky and will NOT slip.
  9. DHammer
    DHammer TPF Noob!
    Aug 22, 2007
    82
    I put both over my head and one arm through (one on each arm obviously) I bought straps that were a little longer than the canon ones and adjusted from there. I usually shoot a 300mm 2.8L or 70-200 2.8L with a 85mm 1.2L. The larger lens is always on a monopod and its the top strap over my neck. Now since I use the monopod I keep the 85mm in front of me as much as possible so the monopod doesn't swing around and pop the second camera.
  10. Snyder
    Snyder TPF Noob!
    Jul 21, 2007
    411
    9
    I travel all around the world
    I have both camera on each shoulder, if they slip my elbow alwas catches it. Though if your wearing body armor there is button straps on the shoulders, it seems like it was designed to hold cameras.
  11. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    the body with the 17-55 and flash is neck strap straight down so that camera rests against my chest and the body with the 70-200 and flash is by a neck strap with my head and left arm is through the strap with camera resting down by my left hip. Both flashes are power by a battery pack on a neck strap with head and right arm through the strap so that the battery rests down by my right hip.
  12. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    If you put one camera around your neck (whichever you are more likely to shoot with more) and place the other camera on your right shoulder, then if it slips your elbow will catch it b/c the hand will be on the other camera.
