How To Install Polarizer Filter...Help!
Discussion in 'Photography Beginners' Forum' started by Nightsblood, Sep 27, 2007.
  1. Nightsblood
    Nightsblood TPF Noob!
    Sep 7, 2007
    97
    Fredericksburg, VA
    I know, this may sound elementary to some but, not me. Ive got a Tamron 17-50 67mm lense, and I got a Hoya 67mm polarizer filter, but I cant figure how to get it on.
    Does the clear lense thats on the Tamron screw off? Am I way off track? I dont want to go forcing stuff. Someone advise me, please.
  2. CPayton
    CPayton TPF Noob!
    Jun 23, 2007
    43
    Yes, the filter that's already on there is probably a haze filter and is more to protect the front of the lens. Just unscrew it and replace it with the polarizer. Use a light touch because if you squeeze the sides of the filter too hard you can make it bind up when you try to remove it.
  3. Nightsblood
    Sep 7, 2007
    97
    Fredericksburg, VA
    THanks for the advice, but it aint budgin'. I'll keep trying.
  4. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    You could just put the CPL on top of the Haze filter if you really can't get it off.
  5. Nightsblood
    Sep 7, 2007
    97
    Fredericksburg, VA
    Dont think that'll work. Filters the screw on type and its the same size as the stock filter ring.
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The UV is probably threaded also. Most are stackable, although it really isn't advisable because of the increased risk of flare.
  7. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Filters can often get 'stuck' and are hard to unscrew. If there is a filter on the lens, keep trying (be careful) and you should eventually get if off. You might need a 'filter wrench'...or just stop by a good photo store and see if they can get it off for you.
    To avoid a stuck filter, is a pencil on the threads before you install it.
  8. CPayton
    CPayton TPF Noob!
    Jun 23, 2007
    43
    Here's the filter wrench that Mike was talking about. Your local camera store will most likely carry something similar.
    Filter Wrench at Adorama
  9. Nightsblood
    Sep 7, 2007
    97
    Fredericksburg, VA
    OK, Ive tried everything Ive found to do. Apparently, rubber gloves and rubber shoe soles are the trick but, no go on mine.
    I guess I'll take her to the camera store tomorrow or pick up the wrench. Ive been beaten by a 2 ounce filter!
  10. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,696
    64
    Missouri
    You may have lost the battle, but I bet you win the war.
  11. six-five-two
    six-five-two TPF Noob!
    Jul 24, 2007
    48
    Just a quick question: Can I use a polarizer filter+ a UV filter at the same time? I really don't want my lens to not be covered in the time I switch from a UV to a polarizer. Haven't bought one yet...
  12. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
how to fit hoya filter
how to fit polarizing filter
how to install uv filter on canon
how to put a circular polarizer filter on a cannon camera
how to put on a polarizing filter
how to put on polarizing filter
hoya filters how to mount
insignia 67 mmcircular polarizer and how do you install it
install uv and polorising filters
installing a polarizing filter
