How to light certain faces?
Discussion in 'Photography Beginners' Forum' started by Blade Borge, May 29, 2008.
  1. Blade Borge
    Blade Borge TPF Noob!
    May 29, 2008
    Hello, first time poster, I'd be interested to know how you light certain faces such as,
    Bald head, double chin, wide face, the overweight, the underweight, broad forehead, long necks, short necks, large ears, pug noses, thin face, wide mouth, etc...
  2. Alfred D.
    Alfred D. TPF Noob!
    May 17, 2008
    381
    We don't light 'm, we Photoshop 'm.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I've found that often it is more about camera angle and lens perspective then lighting.
    For example, portrait lighting generally looks best if it's from above the subject, split lighting can be iffy, especially for hard light, becuase of nose shadows, i've found that if the nose shadow follows the smile lines, it's more flattering then if it's warping over the cheek from the light being eye level with the subject.
    Lens perspective and your angle to the subject is really important for facial features. For example, for people with large noses, longer lenses make the subject more flattering because it compresses the space.
    Lets say Joe Six-Pak has a real honker of a nose, an eye-level headshot of him with a 50mm lens is going to look potentially alot worse then the same shot at 200mm.
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yep but if you open any book about portraiture it will tell you lighting makes as much difference as lens perspective.
    A larger subject will benefit from the slimming effects of rim lighting with a small fill, but then this also causes blemishes in the skin to be brought out more.
    Want to reduce blemishes a big fat soft light source does just that but at the expense of making the subject look a bit fatter. Playing with various combinations of 3/4 front on and side lighting can have quite an effect on the perception of the subject.
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Bald head - Even diffused lighting
    Double chin - Ask them to lift chin up and/or turn head to angles.
    Wide face - 3/4 view shots not straight on
    Overweight - angles and them being higher than I
    The underweight - don't do anything much special, maybe play with angles
    Broad forehead - see wide face
    Long necks - see underweight
    Short necks - see underweight
    well... you see the trend, right? It is a simple fact that you de-emphasize the trait that is negative and emphasize the traits that are positive. The suggestion that you purchase a book on portraiture is a good one. The info that you are asking for can easily fill a book!
  6. Blade Borge
    May 29, 2008
    Any recommendations on such a book? And thanks everyone for your input.
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Wow, not sure you will find it all in one place/book, but a good place to start would be "Master's Guide to Portrait Photography". Google or search for it on Amazon.com.
  8. John David
    John David TPF Noob!
    May 29, 2008
    12
    [FONT='Verdana','sans-serif']JerryPH has the right idea. I agree with what he said. I would also look into different lighting styles...broad, narrow, split, rembrandt, butterfly. They all can be used to accentuate your subject flattering features and minimize their less attractive ones.
    [/FONT]
