You probably should before you comment.I didn't read it all
This not a clear coated car, and if the car and towel are properly washed there is no dirt. And, again, if you have results you are happy with that's cool.but here's a few problems I see.
1. If you have softer clearcoat like on a Honda/Acura then an absorber will marr the surface. Also the absorber has no way of pulling any dirt left from beyond the surface. A good waffle weave Microfiber drying towel will work much better and safer for softer paints.
As noted.but here's a few problems I see.
2. NEVER let the buffer's pad touch any surface other than the car as it is in your picture. Any dirt that accidentally gets in the pad from that surface will just get spun around all over the paint.
3. Dawn.....I suppose it's okay if it's used only before a full detail
Those are on a BBQ grill which gets much hotter from the fire than sitting in the sun.but here's a few problems I see.
4. I would never put a product directly on the paint as you could marr the paint by setting those bottles there. Set a microfiber cloth on the paint and then the product on that. No sense in risking damaging the paint when you're putting as much time into as this.
LWW
