How to remove an overly bright spot
Discussion in 'Digital Discussion & Q&A' started by Deksel, Dec 27, 2008.
  1. Deksel
    Deksel TPF Noob!
    Dec 1, 2008
    13
    The overly bright spot on top of the 3 window from the left is annoying me quite a bit. Any suggestions how I can rectify this with photoshop?
    [​IMG]
    [​IMG]
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Use the clone tool to carefully copy the window to the left over it.
  3. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    Hey Garbz are you back home now? anything decent from your trip? H
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  5. Lostbox
    Lostbox TPF Noob!
    Jan 5, 2009
    28
    I would select an area to the left, bigger than you actually need, copy it into a new layer.
    Move it over the area and use a layer mask and a low opacity brush to blend it in.
    This will avoid the obvious areas sometimes left by the clone tool, and you should be able to remove the hole thing in one go
gimp remove bright flash
how to clean up bright spots on pictures from scanner
how to fix a bright light in a picture
how to fix a bright spot in photoshop
how to prevent bright areas in pictures
how to remove bright spots in photoshop
how to remove light in photoshop
remove bright spot white photoshop
removing bright spots from images
removing bright spots in photoshop
