How to remove red fringing?
Discussion in 'Photography Beginners' Forum' started by RobNZ, Apr 8, 2010.
  1. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    I am after a little advice on the simplest way to remove the red fringing seen on the rocks and tree line?
    A method for Paintshop Pro X2 ideally, however I am sure I could adapt photoshop tips as well.
    [​IMG]
    C&C welcome, I thinks its ok (for the style I shoot) but lacks something really special, my wife however really likes it.
  2. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    Too hard basket?
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Did you shoot with RAW format? If yes, use the software that shipped with the Canon EOS camera (Digital Photo Professional) to remove chromatic aberrations (CA)
  4. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    The "red fringing" is not a sensor based CA issue, thus it can't be fixed by using the CA adjustments during RAW conversion.
    The cause is largely flare with possibly a small amount of lens based chromatic aberration (a totally different animal than sensor based CA) that results in some of the very deep red (near IR) to not focus at the same point as most of the rest of the spectrum. This slightly out of focus light records in the red channel. It is normally quite dim and of little effect, but when such an extremely bright sky is against such dark foreground objects there is enough of it to be visible.
    The only fix is to create a very accurate mask and then darken the masked area of red fringing.
  5. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    What I do is (if you have photoshop) go to filters, distort, lens correction, and then adjust the fringing levels. OR... I also go to hue/saturation and choose the color and turn the saturation and lightness down. I'm sure there are better ways but that's my method.
how to remove red fringing in photoshop
how to remove red lines in photoshop
photoshop remove red fringing
red focus fringing
red fringing
red fringing in digital photos
red fringing photoshop
remove red fringe photoshop
remove red lines from photo
