How to resize RAW without losing too much weight?
Discussion in 'Graphics Programs and Photo Gallery' started by magdabis, Aug 13, 2009.
  1. magdabis
    magdabis TPF Noob!
    Aug 11, 2009
    7
    Hi
    My goal is to get a JPG image which is 2400 x 1600 and is between 2 and 10MB. The problem is I can't achieve it. Original RAW file is about 13.5MB. I make all the adjustment needed (in DPP) and then converst it to JPG. I resize it to 2400 x 1600 when I convert it (there is this option in DPP). The final JPG is 1,6MB. I need at least 2MB. Why do I lose so much weight? What do I do wrong?
    thank you for your help
    Magda
  2. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    RAW files are large because they carry a lot of information. They really aren't' even a true image format...which is why they need to be converted. When you look at a 'RAW image', you are actually looking at an embedded JPEG image that is carried by the RAW file.
    JPEG is a format that is made for reducing image file size. It compresses the information and doesn't carry all that extra baggage that RAW files do. So you end up with much smaller file sizes...which is a a good thing.
    So my question is: why are you concerned about getting bigger files sizes?
    It doesn't relate directly to image quality...although you can certainly reduce the image quality (JPEG compression) to make the file size smaller.
  3. magdabis
    magdabis TPF Noob!
    Aug 11, 2009
    7
    I want to submit a photo for a competition and the requirement is JPG, 2400 x 1600 and between 2 and 10MB. How do I achieve it?
    I don't want to submit 1,6MB and get rejected
    Thanks
    magda
  4. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    I always hate it when they list a minimum file size as a requirement for competition. It just causes confusion.
    What is the resolution of your file? You may be able to change the file size by changing the resolution.
    Also, when you are converting it to JPEG, are you using the maximum quality setting?
  5. magdabis
    magdabis TPF Noob!
    Aug 11, 2009
    7
    Resolution is 350 pixels / inch.
    When I convert to JPG I use max quality setting
  6. KmH
    Apr 9, 2009
    38,479
    5,084
    Iowa
    Resample the image at a higher resolution like 400ppi. Use the Bicubic Sharper algorithm.
    The biggest part of the difference between a RAW data file and JPEG image file is the color bit-depth.
    Raw has a 12 or 14-bit depth and JPEG only has an 8 bit depth.
    12-bit is 4096 variations and 8-bit is only 256 variations.
  7. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    *scratches head* A minimum file size? That's kinda stupid, if you assume people know what they're doing. o_O
  8. Overread
    May 1, 2008
    23,210
    3,831
    UK - England
    Out of interest have you tried contacting the organisers of the compeition about this - it might be that the min photo size is a "guidline" rather than a fixed value rule
  9. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Save the file as a .tiff it should stay > 2mb
  10. MountainPaul
    MountainPaul TPF Noob!
    Feb 14, 2007
    30
    You could ask if the size they require is uncompressed size (in Photoshop) or physical size on hdd. There is a huge difference.
can we resize camera raw files
how to resize a raw file
how to resize raw files
how to resize raw images
raw resize
resize photo to raw
resize raw
resize raw files
resize raw photos
resizing raw images
