How to shoot indoors
Discussion in 'Photography Beginners' Forum' started by joepence, Nov 22, 2008.
  1. joepence
    joepence TPF Noob!
    Jun 10, 2007
    13
    I took some pictures at my daughters basketball game and most of them came out blurry. I tried different settings with not much luck. I have a cannon rebel xt. Does anyone have any suggestions on how to take action pictures indoors?
  2. stsinner
    stsinner TPF Noob!
    Oct 27, 2008
    1,860
    8
    Massachusetts
    Big distance, big flash!!
  3. joepence
    joepence TPF Noob!
    Jun 10, 2007
    13
    Does that mean that without a bigger flash, I won't be able to get any action shots?
  4. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Wider aperture, or use flash.
  5. joepence
    joepence TPF Noob!
    Jun 10, 2007
    13
    What setting do I put it on to get a wider aperture?
  6. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    You put a different lens on.
  7. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,898
    11
    Arizona
    What lens are you using? Remember to use a fast enough shutter speed (Use Tv or Manual, not auto). If your lens doesn't have a large enough aperture (small f#) you might not be able to get the images you need unless you add more light. Unfortunately, fast lenses (small f#) tend to be more pricey.
  8. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    You will also have to jack up the ISO on it.
  9. Ecas32
    Ecas32 TPF Noob!
    Nov 21, 2008
    323
    Florida
    faster shutter speed and higher ISO
  10. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    First of all, in order to freeze an action, you need to use a fast shutter speed setting. With fast shutter speed, less light is allow to enter the camera. If it is a outdoor events, usually it is not going to be a big problem because there are plenty of light. The problem is with indoor events.
    Lightning inside the stadium usually is not as bright as outdoor. In order to take a proper exposed photos with your camera, you need to set a wider aperture (lower aperture number in your camera) so that it allow more light to go in.
    The maximum aperture of your setup depends on the lens you use with your camera. If the lens you current cannot set to a lower number such as F/2.8, F/1.8, F/1.4 or F/1.2 ... then you may need to get a different lens. The wide aperture lens is usually refereed as fast lens.
    Beside using a wide aperture lens, change the ISO settings to a higher number may also help.
    As for the flash, you will need to very powerful one, I doubt the build-in camera flash can do the job.
  11. joepence
    joepence TPF Noob!
    Jun 10, 2007
    13
    Thank you for the advice. Any ideas on a lens for me to buy?
  12. impressme
    impressme TPF Noob!
    Nov 12, 2008
    170
    Central, New Jersey
    reg- short, almost rude, answers aren't helping anyone- If you're going to respond atleast give more than what you seem to think is a "dumb answer to a dumb question"- REMEMBER- this is a beginners forum for a reason- so BEGINNERS can post and receive HELPFUL advice!
    Joepence- thanks for asking the question, I'm pretty new to this whole photography thing and this is a situation I have yet to shoot in!
