How to shoot the Sinking Sun
Discussion in 'Photography Beginners' Forum' started by norris_watkins, Jul 16, 2008.
  1. norris_watkins
    norris_watkins TPF Noob!
    Jul 13, 2008
    11
    I tried without muc result to take a picture of teh Sinking Evening Sun.
    No matter what I did, the resulting picture was not as vivid as the ones I ve seen. It looked very plain even compared to looking at the scene with my eyes. ( The richness of color was simply missing )
    Am I supposed to use filters ?
    When I tried to use, long exposures, I evnded up getting washed out pictures.
    Any ideas ?
    --nw
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    You can't really compare what the human eye sees to what a camera is capable of doing. Our eyes are constantly moving and adjusting, so our brain can take in a whole scene with drastically different tones. A camera only captures the photo at a specific exposure. If you set the exposure for the bright sun/sky...then the rest of the image will probably be very dark. If you set the exposure for the darker areas, then the bright areas will get blown out.
    It's a balancing act that photographers fight with all the time. But if you have an idea of what you want and what your limits are, it should be easier to get there.
    There are things you can do to help. A split or gradient filter can help to even out the exposure, or you can take multiple exposures at different levels and combine them with software.
  3. Easy_Target
    Easy_Target TPF Noob!
    Aug 4, 2007
    380
    I thought the camera manufacturers advised us not to aim the camera at the sun as it would damage the sensor?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It would probably damage your eyes before damaging the sensor.
  5. Computer_Generated
    Computer_Generated TPF Noob!
    Jul 6, 2008
    155
    Canada
    Agree, can't really add much... as I've only taken a handful of these types of pictures, I usually do like a 5 stop bracket, pick the best or like it was already mentioned combine with software.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Good point...I forgot to mention bracketing.
    For shooting something like sunset/sunrise....different exposure levels can give you dramatically different results. So take a handful of shots with different exposures and then you can choose the best ones later.
    This just reminded me that I took a whole bunch of sunset photos while camping, earlier this month. I haven't even off loaded the card yet.
  7. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    You can also use filters. A graduated Neutral Densitiy is great for it or, try a Circular Polarizer. The graduated filter is the best choice though.
  8. kcon
    kcon TPF Noob!
    May 26, 2008
    59
    i remember reading when photographing sunsets it helps to underexpose the image slightly, this will make the oranges more vivid and less washed out
  9. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,147
    2,017
    In the country just north of Toronto, Canada
    This is the first sunset of 2008, taken from our carport. Unfortunately I lost the original & only have the small version. :-x
    [​IMG]
  10. norris_watkins
    Jul 13, 2008
    11
    Ron Evers :
    That is a great picture. If you still have the exif data, could you post the lens/time/exposure/iso as well as whether you used a filter or not
    --nw
  11. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    in case Ron doesn't return to the thread his exif
    Camera Make: NIKON
    Camera Model: E2100
    Image Date: 2008:01:01 22:48:25
    Flash Used: Yes (Auto)
    Focal Length: 4.7mm (35mm equivalent: 36mm)
    Exposure Time: 0.033 s (1/30)
    Aperture: f/2.6
    ISO equiv: 126
    White Balance: Auto
    Metering Mode: Matrix
    Exposure: program (Auto)
    It is a nice shot..
    OP - I'll second the use to 2 or 4 stop ND grads for setting suns... that is if you interested in exposing the foreground...
  12. Ron Evers
    Jun 28, 2008
    6,147
    2,017
    Thanks for that dEARlEADER. I was trying to copy that from my picture but I could only highlight one line @ a time to copy.
    The camera is a pocket type point & shoot. My wife called me to the door & asked me to take a picture.
