How to use a Manual flash on Nikon D300
Discussion in 'Nikon Cameras' started by iKokomo, Oct 16, 2017.
  1. iKokomo
    iKokomo TPF Noob!
    Jun 11, 2011
    101
    I have an older manual flash that connects via the PC Sync port (the trigger voltage is 6v so it is safe) so when I plug it in and take a photo, the flash does not fire. The test button fires the flash so I know the bulb is ok.
    I have also tried the pc sync to hot shoe adapter on a couple of Nikon cameras and it still does not work.
    Is there a menu setting on the camera that I need to set for manual flash mode? I know there is a setting for manual lenses is it the same for a flash?
    Thanks!
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    No. A trigger signal is sent to the hot shoe every time the shutter is pressed, regardless of whether or not a flash is present. Have you tried different cords, and what happens if you put the flash directly in the hot shoe?
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    There might be a setting, buried in the camera's menu that might tell the flash not to fire, but I wouldn't count on that being the problem.
    Normally, the flash circuit is available to fire every time the shutter opens. If there is a flash attached via the hot shoe or PC connection, then it should fire.
    Does the flash have a hot shoe? Have you tried it on-camera? I would guess that the PC port or the cable is shot.
    • Like Like x 1
  4. KmH
    Apr 9, 2009
    40,751
    5,588
    Iowa
    Please specify, which 'older manual flash' you are using?
