How to use Old Tele-Macro lens
Discussion in 'Photography Beginners' Forum' started by mdmosta319, Oct 19, 2017.
  1. mdmosta319
    mdmosta319 TPF Noob!
    May 13, 2017
    20
    [​IMG]
    This is my lens. Tamron Af 90-300mm f4.5-5.6
    It says Tele-Macro lens. Other lens has button for Macro but this one has no button.
    Is it Macro in its full length or only @300 or what?
  2. petrochemist
    petrochemist No longer a newbie, moving up!
    Mar 9, 2014
    1,086
    264
    North Essex UK
    Probably not true macro at all. Macro-zooms often cheat & use the standard 6x4 print size rather than the sensor image size to calculate 'macro' magnifications.
    Depending on the design the largest magnification may well be at the shortest focal length -which needs less extension to get higher magnifications. Nearly all 'macro zooms' are purely closer focusing zooms.
    Typically 'macro zooms' will reach ~1/4 life size. This can be enough to give great close-up results. Checking on-line reviews it seems this one will get to ~half life size.
    • Like Like x 1
  3. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    Some Tele macros will only let you get closer focus if it's in a certain position. I have a Vivatar 80-200 that allows closer focusing at 80mm setting. The focus ring actually turns farther when in that position.
  4. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    The term "macro" on zoom lenses is more of a marketing term than a meaningful one. It means it will focus closer than some other lens without defining what some other lens is.
  5. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,668
    8,120
    Iowa
    Buttons are not a prerequisite for macro lenses.
