How would you fix this photo?
Discussion in 'Digital Discussion & Q&A' started by Isabella111, Apr 21, 2010.
  1. Isabella111
    Isabella111 TPF Noob!
    Apr 21, 2010
  2. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    48
    Arkansas
    It appears out of focus
  3. LaFoto
    Feb 1, 2004
    34,814
    814
    Lower Saxony, Germany
    Well, I'd definitely leave in all four windows, and would only crop out the bits of green grass at the bottom. Not much else.
    Apart from that I'd probably up the contrasts some more, play around with saturation just to see how far that would take me, or with desaturated versions, depending ... and I'd add an Unsharp Mask to bring out some more sharpness.
  4. aastropak
    aastropak TPF Noob!
    Apr 22, 2010
    hi,
    i would like to remove all the rust(corroded one in the pic) and later will add some lighting effects and remove the wire which is hanging over the third one..
    and later will add some Hue & satuaration along wid contrast levels accordingly to hihglight the pic
  5. aastropak
    aastropak TPF Noob!
    Apr 22, 2010
    hi,
    and later will add some Hue & satuaration along wid contrast levels accordingly to highlight the pic
    __________________
  6. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    I am curious
    what are you seeing in this shot?
  7. Russell.T
    Russell.T TPF Noob!
    May 3, 2010
    Tallahassee, FL
    I'm thinking the same, Pierre. What exactly are you intending for this picture to convey?
  8. KmH
    Apr 9, 2009
    39,234
    5,288
    Iowa
    You don't have edit preferences selected in your profile.
    Let me know if you want me to take the edit down.
    I corrected the distortion some. (At the sides) Cropped out the grass.
    I edited to make the uninteresting stuff recede, but kept the leading line.
    [​IMG]
  9. eriqalan
    eriqalan TPF Noob!
    May 5, 2010
    42
    Portland, OR
    1) forget any "rules" like the so called rule of thirds (actually derived from how much weight a roof can support of all things and it isn't even thirds but 1 to 1.61..... - an irrational fraction). In this case you have an image in which that is improper in any event; the idea of the rule is that you have a single subject that you put at the "thirds" intersection (in this case the entire building is the subject - to apply the rule here you would have to see the building from far away, by itself in a field ...)
    2) you have two different stories told by the crop - the original dark, dank, dilapidated 4 window shot that looks like an abandoned building crowded among other buildings and the brighter, 3 window shot that looks like it is apart from other buldings
    Why did you crop that window out? What did that add to the picture?
    Why did you brighten it like that? what does that add to the picture?
    When I teach classes I try as a first exercise to get students to do this exercise: look at this picture and describe what you see, what it says to you. For example "The orange short-haired tabby cat chased the red and white striped rubber ball down the curved black wrought-iron railed staircase past the terra cotta pots with agave and yellow-and-red canna flowers, with the vine covered stucco wall on the other side, to the red brick tiled floor below with the fluffy white rugs on the floor" it takes all that description to build the image that ONE picture can show - that is the job of the photographer - to tell the story with one image
    Do that with your picture - what story are you trying to tell? Look at both images and try the same exercise
    Photographers do not take pictures by "rules". they take pictures on what they see, the beauty, the horror, the glory, the fear, the joy; the vibrancy (or life) or the sorrow, emptiness, death of these buildings as you seem to have done
    Let the critics come up with remarks like some fanciful rules; just take pictures of what appeals to you
  10. magkelly
    magkelly TPF Noob!
    May 5, 2010
    270
    USA
    It is a bit blurry that can only be helped so much, but first I cropped it a bit then I tweaked the exposure and offset, used the smart sharpen filter and the hand sharpen tool in Photoshop. I then enhanced the reds in the picture by tweaking the color and levels and by using a red photo filter on a very subtle setting. I liked the rusty wire and the rust around the window. I thought they added character to the shot actually and I wouldn't get rid of them. It is what it is, a gritty shot of an old, decaying building. Making it too pretty kills the focus of the shot IMHO.
    [​IMG]
  11. Jeff Colburn
    Jeff Colburn TPF Noob!
    Aug 6, 2007
    300
    Sedona, AZ
    Did you shoot this through a window screen? It has that look.
    As others have said, there is no main subject to this image. Now, if you were to photograph just one of the windows (shoot each one separately and make them a series) that would improve things. Also, shooting straight on is a little static.
    Have Fun,
    Jeff
  12. KmH
    Apr 9, 2009
    39,234
    5,288
    Iowa
    Could the OP be a one post member? It's been a couple of weeks.
photoshop and removing window screen effects and masks
