Hoya Filters
Discussion in 'Photography Beginners' Forum' started by Eyezayuh, May 21, 2009.
  1. Eyezayuh
    Eyezayuh TPF Noob!
    Feb 2, 2009
    13
    Eugene, Or
    I have a Canon Sx10 is and am thinking about getting the lensmate filter adapter for it but was wondering a few things...
    Do they work well?
    Which is going to give me better results, The Moose Hoya or HMC Circular Polarizer?
    Your thoughts on using them...
    Thanks
  2. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    The lens mate seems like it would work ok at holding a filter on.
    As for the filter choices its really up to you. My circular polarizer's are standard. The Moose is a combination of a CPL and a 81A warming filter. The 81A helps to bring out colors on dull days or flat lighting. I think you would be happy with either.
  3. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    The only advice I'd give is that I try to be conservative with using filters that add something into the image (colors, warming / cooling filters, etc.) because most of that stuff can be easily added in post.
    I'd imagine you could cool the image down in post as well if you didn't want the warming affect but then you have to ask yourself why bother putting the warming affect in the filter???
  4. Eyezayuh
    Eyezayuh TPF Noob!
    Feb 2, 2009
    13
    Eugene, Or
    I'm pretty new to photography so I wasn't sure if they were worth the money even. The HMC is multi coated, does that make a big enough difference to pay the extra $30 over the moose?
    I also read that the moose wasn't good for digital photography.
    And I don't really know how to do those in photoshop
  5. benhasajeep
    May 4, 2006
    4,021
    494
    Yes, the warming affect can be reproduced by software.
    Multicoating is a big plus. It helps to keep unwanted reflections down. I am not sure why the moose would not be good for digital.
    If it were me a multicoated circular polarizer would be the choice.
  6. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    I would pay extra for the multi-coating (especially since it's only $30). It'll help reduce glare and scratching.
    Some filters can't be reproduced like Infrared filters, polarizers and ND filters. Those are worth buying. Other filters can be reproduced, easily.
    That's probably why they say it's not recommended for digital. If you shoot in RAW you'll likely do some white balance tweaks in post production and that would remove any warming affect that the filter would add.
    To help explain why the warming affect is probably a waste I'll try to give an example to illustrate the point. If you shoot RAW you'll need a program to convert it into whatever format you want (jpeg, tiff, etc). You'll load the pic into the RAW conversion software and you'll see a ton of basic editing options like exposure compensation, contrast, fill light and others.
    You'll also see some White Balance tweaks like Temperature and Tint. To achieve the same affect that the warming filter gives... you'd slide the Temperature slider a bit to the right. That's it. That tweak will be in any RAW conversion software you can find too. Likewise most programs have a Custom WB setting where you click on a neutral color in the image and the software sets the WB to that color. If you have the warming filter on, doing that will remove the warming affect.
    So you can buy the warming polarizer filter if you want to but the warming affect will most likely be wasted.
  7. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Maybe it'd be a good idea to download some RAW conversion software and take a look at the White Balance tweaks. Once you understand that (and it's not too in depth), you'll understand why the warming filter isn't needed for digital.
  8. Eyezayuh
    Eyezayuh TPF Noob!
    Feb 2, 2009
    13
    Eugene, Or
    alright thanks, i think ill get the multi coat CIR. POL.
