You are Wrong, plain and simple. DOF and Bokeh are two separate entities, but I will respect your right to be wrong in your own mind if it makes you happy.
Exactly.Bokeh is the quality, the character, the look, the nature of, the out of focus areas.
Why, thats wrong. Bokeh is a property of the lens. Plain and simple. Just like any other lens attribute. Even if you statistically get certain Bokeh properties from other lens attributes, you cannot reliably conclude the quality of the Bokeh from the other lens attributes. Its a result of the lens formula - what lens elements, what glas types, etc - just like any other attribute of the lens.Things like spherical aberration, coma correction, diaphragm shape and placement within the lens, chromatic aberration correction levels, microcontrast, and more--all those things influence the character of the OOF areas; that is the original meaning of bokeh.
Just like with any other question of beauty, the answer is ultimately subjective, even if most people will agree creamy Bokeh is pretty and nervous Bokeh ... not so much.There are only 4 kinds of Bokeh. Great, Good, Poor, and OMG that Sucks!!!
Solarflare said:[
Why, thats wrong. Bokeh is a property of the lens. Plain and simple. Just like any other lens attribute. Even if you statistically get certain Bokeh properties from other lens attributes, you cannot reliably conclude the quality of the Bokeh from the other lens attributes. Its a result of the lens formula - what lens elements, what glas types, etc - just like any other attribute of the lens.Derrel said:Things like spherical aberration, coma correction, diaphragm shape and placement within the lens, chromatic aberration correction levels, microcontrast, and more--all those things influence the character of the OOF areas; that is the original meaning of bokeh.
No. Bokeh is not semantics. It describes the quality of the OOF area. Period. Check out the DOF of the canon 50mm f1.8 and f1.4 at f2 and tell me that they are the same. The DOF and the Bokeh is totally different.
I'm not saying you'd see a difference in that case.
I'm saying that if you take an f/1.8 lens and stop it down to a smaller aperture, the out of focus area behind the point of focus is going to become less pronounced. So take that 50 f1.4 and compare an image at f1.4 with one at f4, and then another at f8... and then tell me that the bokeh is the same between the 3. It isn't: you'll have more pronounced bokeh wide open than stopped down. And therefore aperture affects bokeh. Period.
I'm not going to get tied up further in arguing the semantics of it or dragging this thread further away from the OP's question, so I'm leaving this thread following this post. I'll be out making photos while you all bicker about semantics.
Edit: I wanted to simply add that maybe this isn't how the term bokeh has traditionally been used. But in modern photography and language in general the meaning of *many* terms has changed over time. 99% of modern photographers use the term bokeh simply to describe the out of focus area that appears behind the point of focus.
Yeah....it's not the weight as much as the terrible forward-torque or what I call nose-dive, that it puts on the wrist...it's so fat, and all the weight is just a few inches in front of the body. I found the 300/2.8 much easier to shoot hand-held or monopodded, and the 400/3.5 which is 96 ounces, is much easier too. Of all the big glass I've ever owned, the 200 f/2 had the absolute worst balance...just ungainly. Awkward. The 200/2 was okay on a monopod, but it's a bad lens for hand-held shooting.Just terrible balance, even with a D2x or D3x and a lot of weight as ballast. On a half-height body without a grip, it suuuuuuucked.
gryphonslair99 said:Go to Hobby Lobby to their decorative door knob section and pick out one that fits your palm. Attach a 1/4" threaded rod and you are good. You may have to tap the knob to accept 1/4" threaded rod. Works wonderfully.
