HX90V
Discussion in 'Photography Beginners' Forum' started by danisat, Oct 11, 2017.
  1. danisat
    danisat TPF Noob!
    Oct 11, 2017
    31
    hi
    i have a question about the hx90v sony
    what is the maximum distance that I can take in focus a photograph with the optical zoom to the maximum?
  2. Low_Sky
    Low_Sky No longer a newbie, moving up!
    Jun 9, 2013
    263
    168
    Alaska
    The maximum distance you can focus is infinity. If you're asking about the minimum focus distance, it's 8.2 feet in all modes except iAuto (then it's 0.16 feet).
    Sent from my iPhone using Tapatalk
  3. danisat
    danisat TPF Noob!
    Oct 11, 2017
    31
    problemas with DSC07872.jpg the sharpness o focus you see?
  4. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,756
    419
    That image looks more like it is an issue on how you are attaining focus. The camera looks like it is set to focus on the closest item, in this case the closest is the base of the palm frond and not the parrot.
    You can probably select a focus point. Use one of the custom buttons and set that for selecting the Focus Mode of the camera. That can make it easier to be in a focus mode that is best for the subject.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,465
    15,207
    USA
    Si...yo veo problema con el objectivo: parece a mi como aberracion chromatico en la cabeza del pajaro.
    • Agree Agree x 1
  6. danisat
    danisat TPF Noob!
    Oct 11, 2017
    31
    hola, y cual puede ser el problema? , vuelvo a hacer la pregunta
    cuando el zoom esta al maximo , 720 mm hasta que distancia me permite sacar una fotografia en foco>?
    hello, and what may be the problem? I ask the question again
    when the zoom is at the maximum, 720 mm until the distance allows me to take a photograph in focus>?
  7. Dave442
    Feb 1, 2015
    1,756
    419
    You need to focus on a subject like the parrot using Center AF and the Lock function to hold that focus point - recompose - take picture. Or use the Flexible Spot AF and move the focus point over your subject and take the picture. If you shoot in Multi AF then you should see a green box around what is in focus when you push the shutter button half-way.
    The only note I see regarding close focus at the telephoto end of the zoom range is 1.20 meters. I would put the camera in manual focus and just see how close it will focus.
    Espero que tiene el manual del usuario. En caso que no, aquí es el version en ingles - ver paginas 56 a 61...
    https://docs.sony.com/release/DSC-HX90V_help.pdf
  8. danisat
    danisat TPF Noob!
    Oct 11, 2017
    31
    Thanks you
    I know what you explain
    But i think that My camera have a proble m with the focus when i put on the máximum optical zoom...:(
  9. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,351
    7,797
    Michigan
    You need to have a shutter remote and a tripod for a shot like this. Even then, it may not come out with clarity. Once you get into that digital zoom focal length
    (DIGITAL ZOOM (STILL IMAGE)Up to 120x)
    , all bets are off. You have to stabilize the camera, turn off image stabilization. I bet the hand shake icon came on. it also appears the focus point missed the bird and hit the branches to the left.
  10. Low_Sky
    Jun 9, 2013
    263
    168
    Alaska
    It looks like you missed focus on the bird in your image, but it's also important to remember that most zoom lenses are not at their sharpest at the extreme ends of their zoom range. Even if you get the focus perfect, the image still may not be sharp enough for your liking.
  11. danisat
    danisat TPF Noob!
    Oct 11, 2017
    31
    Hi
    Today a picture ...optical zoom 30 x 720 mm
  12. jcdeboever
    Sep 5, 2015
    14,351
    7,797
    Michigan
    Have you tried a tripod, remote shutter, and stabilization off?
