I almost deleted it
Discussion in 'People Photography' started by seesaw, May 29, 2007.
  1. seesaw
    seesaw TPF Noob!
    Apr 2, 2007
    22
    But after playing with it a little bit, I kinda like it! But I know it can be better to make the bike stand out more. Any suggestions? Also I cropped showing the jump more rather than the destination. Which would be a better perspective?
    [​IMG]
  2. elle
    elle TPF Noob!
    Apr 14, 2007
    54
    I only had a really quick play, with a bit longer I could probably make it a bit better... but here you go. I played with the levels a bit and upped the saturation.
    [​IMG]
  3. koda-46
    koda-46 TPF Noob!
    May 21, 2007
    206
    over exposed..... it looks as if u took it with a disposible camera
  4. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    It's actually underexposed. The sky is blown, but the ground and bike are underexposed. Also there is a bad case of lens flare.
  5. DigitalDiva
    DigitalDiva TPF Noob!
    Apr 15, 2007
    309
    The Netherlands
    No offense to you, elle, but your adjustments created major banding in that image. It looks incredibly digital now.
  6. LaFoto
    Feb 1, 2004
    34,814
    814
    Lower Saxony, Germany
    Hmm. This photo is one that only you can know if you want to keep it or not. Technically it went horribly wrong. But if capturing THIS moment (of the bike being airborne) is what makes you happy about the photo, so happy that your feeling of success overrides all the technical flaws given, then do keep it by all means.
    Lighting alone (not to mention your crop and subsequent composition as we see it here, which does not leave the bike much room to fly into) is really a problem.
    Is the photo underexposed? Or overexposed? The histogramme of your photo as shown here is the craziest I have ever seen:
    [​IMG]
    So where to begin if you want to rescue this?
    My steps ... leading to my edit, though I am not even sure you asked for one? Tip for next time: don't photograph such an action scene right against the sun. The dynamics are against anything your camera can deal with (so I think).
    Step 1:
    [​IMG]
    Step 2:
    [​IMG]
    Step 3:
    [​IMG]
    Step 4:
    [​IMG]
    Step 5:
    [​IMG]
    And I decided to end with Step 5 as "my edit" (but I am not happy with it and if this were my photo, it'd be gone):
    [​IMG]
  7. LaFoto
    Feb 1, 2004
    34,814
    814
    DigitalDiva, what is "banding"? Can you tell me? Did I create the same, maybe?
  8. seesaw
    seesaw TPF Noob!
    Apr 2, 2007
    22
    Yep, technically speaking, it sucks, but there was just something I liked about it. But I've liked seeing what some of you have done with it. I'm just trying to get some different perspectives- I am new to this and only know what I like, not what is good in the technical sense. And maybe I'm fond of it because it was different from the other pictures I have seen from the race track- almost like a sillouette.
    Corinna you are a wonderful teacher! Thank you for going through those steps so thouroughly.
  9. nabero
    nabero TPF Noob!
    Mar 2, 2007
    869
    Pittsburgh, Pennsylvania
    Okay, yeh, I agree that technically this is something of a disaster...
    BUT I actually really like it. The lens flare makes the rider glow...there's something about it that I like...but I'm not sure how to explain it....kind of otherworldly. Godlike-adrenaline-induced-something-or-other...it conveys urgency....Like I said, I can't figure out how to explain it... but I do like it :)
  10. DigitalDiva
    Apr 15, 2007
    309
    The Netherlands
    Hi, LaFoto. Banding is noticeable transitions in areas of smooth color. When you make adjustments to a digital image, you run the risk of this happening. It is incredibly apparent when you print as there are sort of blocks of colour instead of a smooth transition that you get with continuous tone that you get with a traditional film image. If you look, especially where colours meet, you will see a sort of blockiness. HTH!
