I do not know how to use flash!!!!
Discussion in 'Photography Beginners' Forum' started by edouble, Jul 10, 2010.
  1. edouble
    edouble TPF Noob!
    May 24, 2009
    715
    NEPA
    I avoid using flash at all costs. The only flash I have is the built in speedlight on my D5000. Even with -3.0 flash compensation my pictures are completely washed out of any detail due to flash brightness. Using LR3 I was not able to restore any detail in areas that have been completely washed out from the flash.
    Pleas help me use my built in speedlight to take good pictures!!!!
    These are out of the camera pictures processed from RAW to JPEG then uploaded to photobucket.
    [​IMG]
    [​IMG]
  2. rusty9
    rusty9 TPF Noob!
    Apr 13, 2009
    563
    Madison, MS
    what's your shutter speed. the flash on that camera can work up to 1/200th. if you are going slower than that, you can speed it up and it will expose it better.
  3. edouble
    edouble TPF Noob!
    May 24, 2009
    715
    NEPA
    Exposure time was 1/60th sec, f/5.6, 55mm, ISO 200
  4. o hey tyler
    o hey tyler Been spending a lot of time on here!
    Aug 3, 2009
    9,782
    2,722
    Maine
    Camera: Nikon D5000
    Lens: 55 mm (Max aperture f/5.7)
    Exposure: Auto exposure, Aperture-priority AE, 1/60 sec, f/5.6, ISO 200
    Flash: On, Return not detected
    Jack up yo 'sposure bro. 1/150s @f/5.6
  5. rusty9
    rusty9 TPF Noob!
    Apr 13, 2009
    563
    Madison, MS
    well you can do 1/200 with the flash. that will help
  6. edouble
    edouble TPF Noob!
    May 24, 2009
    715
    NEPA
    I was expecting the camera to adjust exposure correctly - I thought wrong.
  7. MrBarney
    MrBarney TPF Noob!
    Jun 7, 2010
    202
    UK
    If he's in Av, then the camera should be exposing for the background at ambient light (1/60, f5.6 sounds somewhere near) and the flash should be reduced automatically to match. I understood that shutter speed doesn't have a lot to do with flash exposures anyway as it's so brief. You could reduce the aperture, maybe f8 or f11 which would reduce the flash exposure but Av mode would then move to an even slower shutter to expose the background properly.
    The item that struck me was "return light not detected". At that distance, that can't be right, surely? It would cause the flash to put out full power though.
    I've had a search on google but can't find out how the camera detects the return. Could you perhaps be covering one of the sensors with your finger? It might be worth looking that up in the manual.
  8. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Iso should be lower as well.
    Are you sure you may not have put your flash to +3, instead of -3?
  9. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Hahhaha.. I just bought a flash too.. I was thinking the same thing! I think we are at the same level when it comes to flash photography right now.
  10. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    due to flash sync being pretty low shutter speeds its best to work manual or aperture priority, if your close to a subject close the lens down f8-f11-f16, if at distance open it up, simples. H
  11. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Did you mean shutter priority?
  12. edouble
    edouble TPF Noob!
    May 24, 2009
    715
    NEPA
    I was using a Nikkor 18-55mm lens. I believe I was too close to the subject and my aperature should have been between f/8-11 as well. I do not know what the minimum flash distance is for this lens but I was on average 1-4 feet away from the dog.
    ISO 200 is the optimum lowest ISO for the D5000. The D5000 has flash compensation values from +1 to -3.
    Flash photography has shown its ugly head LOL
    I was shooting in aperature priority. My camera was set to matrix metering which activates the camera i-ttl function which should adjust flash output considering ambient light and subject exposure. I think slow sync or rear curtain flash would have helped with a poorly lit shiny dog that I was trying to photograph. Whatcha think?
how do i know when to use flash
