I got some new stuff ... (thumbs nose at Dany)
Discussion in 'Collector's Corner' started by dxqcanada, Nov 7, 2017.
  1. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,182
    940
    Woodbridge, Ontario, Canada
    Ah, sounds the shutter blades.
    The one I am working on has a sticky aperture and shutter blades.
    I noticed that sometimes the shutter blades get stuck ... if I put slight pressure on them, it trips ... so this tells me that there is substance on them to make them stick. The easiest way of getting to the shutter blades is by removing the rear lens group ... then wash'n work the blades.
    It is not easy to take this apart to do a real cleaning.
  2. Peeb
    Peeb Semi-automatic Mediocrity Generator Supporting Member
    Jul 16, 2015
    2,772
    1,726
    Oklahoma
    I had a G-III back when. Difficult to focus but super quiet shutter release and great image quality!
  3. smithdan
    smithdan No longer a newbie, moving up!
    Sep 1, 2012
    534
    476
    Southwest Alberta Canada.
    I tried to wash, the shutter out first but from the front. Remember that there was really no access. The whole innards are extremely dirty so taking top and bottom off will be useful. Aperture blades are frozen as well. Thanks for the tip about opening up from the rear. I'll try and not wreck anything and if all doesn't go well I'll ship it off to you for parts.
  4. dxqcanada
    Dec 4, 2008
    6,182
    940
    Loosen rear cell with spanner wrench. Turn off the cell by hand.
    Set shutter and release.
    If no shutter movement ... press the blades a bit, and they might release.
    Wash blades with lighter fluid
    Exercise shutter
    Let dry
    Repeat until shutter and aperture are freely moving ... note that aperture only gets set in position after shutter is charged.
    • Useful Useful x 1
  5. smithdan
    Sep 1, 2012
    534
    476
    I don't have tools for removing those rings especially with the limited access of the rear ones. Gave everything a good soak with Ronsonol and will carefully try again. Thanks for your help Dennis. Did however get the aperature blades to free up and the shutter to fire reluctantly a couple of times. Think we're on the right track.
  6. dxqcanada
    Dec 4, 2008
    6,182
    940
    Ah, if you ever want to continue working on cameras ... a lens spanner wrench is very important.
  7. smithdan
    Sep 1, 2012
    534
    476
    Too true! Up to now most of my repair attempts have been on simpler cameras.
  8. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    What worked for me is pure Naphta from the local hardware store. I take about a half a cup and add three to four drops of Nyoil (google it to see where you can get it), mix well and apply a few drops of this mixture to the frozen shutter. Great for all little fine gears as well.
  9. dxqcanada
    Dec 4, 2008
    6,182
    940
    Hmm, you introduce mineral oil ? I thought shutters need to be dry ?
    tai-lubricants
  10. Mitica100
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    Actually yes. In repairing some of the large and medium format shutters I was able to use the above formula without having any oily deposits on the shutter leaves. Using Naphta alone will freeze shutters, while adding that Nyoil will ever so slightly lubricate the moving parts. I would not use Nyoil as is, undiluted.
  11. dxqcanada
    Dec 4, 2008
    6,182
    940
    Hmm ... I have a good candidate to try that on.
    Time to buy some Nyoil.
    • Like Like x 1
  12. Mitica100
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    Good. Let me know how it worked out. :1247:
