I Have A Question about D40's & Lenses
Discussion in 'Photography Beginners' Forum' started by tkaat, Jul 21, 2008.
  1. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    I have a D40 and I know about it can only auto-focus with lenses that have the motors in them but does that mean that I wouldn't be able to put a older lens on and manually focus and the camera would recognise it/ let me change the aperture & shutter speed???:confused:
  2. potownrob
    potownrob TPF Noob!
    Jul 8, 2008
    312
    Poughkeepsie, NY
    I am pretty sure at least the AF-D lenses will work for everything but autofocusing on the D40, if not most AF lenses. Not positive about aperture control on older lenses. Once I get my 50mm f/1.8 I'll be able to tell you if the aperture is adjusted in-camera. I think it should since it's AF-D. A lot of if not all of the Nikkor lenses from this decade are at least AF-D. The shutter definitely is set in-camera since the shutter is part of the camera body and not the lens...
  3. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    No... You will be able to use non-afs lenses with the only caveat being lack of autofocus...
    I only have one lens that will autofocus on my D60. You'll get the hang of it. It may even make you a better photographer.
  4. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,696
    64
    Missouri
    You can use "virtually" any SLR lens Nikon has ever made on the D40 (with a couple exceptions that are extremely rare and there's no way you would buy one by accident... and the Pronea lenses which don't fit anything except one of those horrible cameras).
    With Nikon AF lenses (again, with extremely rare and expensive exceptions) will all work just fine including metering... some just won't autofocus.
    You can use manual focus lenses, but they (obviously) won't autofocus and the metering system won't work either... but you CAN use them.
  5. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    Thanks
