JhoZ
- Joined
- Jun 3, 2014
- Messages
- 1
- Reaction score
- 0
- Location
- new york
- Can others edit my Photos
- Photos NOT OK to edit
I got this camera, I used a 35mm 200 film that I found in my mums cupboard, it has been there a while...will the pictures be ok? I also set the shutter speed to 60 (as I was told to use this setting without the flash) I then made sure the needle in the viewer was in the middle (30 looked like the middle to me) I then focused and shoot...are these the right settings in order for the pictures to not be over or under exposed? Any help with this camera will be great as I am new to film photography! I have used the film, pressed the button and the bottom and twisted it back into it's casing using the button on the top...no film is hanging out, should there be? The camera didn't come with a manual as I bought it from a second hand shop! I am using a 50mm lens.
Thanks so much
Thanks so much
