I just lost pictures from reformatting card
Discussion in 'Digital Discussion & Q&A' started by Ryan Piggott, Oct 25, 2009.
  1. Ryan Piggott
    Ryan Piggott TPF Noob!
    Oct 19, 2009
    54
    Folsom CA
    I did a quick search here and searched google and found a few things, but not much surprisingly. Im sure its been discussed before.
    I got the "FORM" error on my d70s just a few minutes ago. first of all, why did it do this randomly, and what does it mean to format a card?
    So i held down both format buttons and reformatted it. Now the pictures i took are gone. Luckily i only had a few pictures that i just took that i really don't care too much about losing, but if this happens at the race this weekend, im in trouble!
    I need to know how to recover the pictures, Thanks.
  2. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Formatting a memory card will always delete all your pictures. It usually tells you all your images will be erased before you follow through. (at least my cameras do)
  3. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    What card is it? Some cards come with recovery software.
    Yeah, reformatting will delete everything on the card...that's what it does.
    Don't reformat your card if there are still pictures you want on it.
    Technically, it doesn't actually delete anything though, it just tells the camera that it's OK to overwrite the information on it (very basic explanation). You may still be able to recover whatever you had on it...
  4. Ryan Piggott
    Oct 19, 2009
    54
    Folsom CA
    Im really not worried about recovering the pictures that were on it, there were a few i just took around the house but nothing i'll miss.
    The card is a Lexar Professional UDMA 2gb 300xspeed.
    So next time my camera tells me to reformat, and won't let me take pictures, what do i do? stop shooting the race for the day, yank the card and download the pictures... then reformat?
    i also have the original card, so i guess what i can do is bring it as a backup to the race so i can swap it in if this card gets a "FORM" error.
  5. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Weird... My camera doesn't do that.
    Was the card full?
    Just download all the pictures to your computer before you reformat it.
  6. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Always have backups...
    simple solution or if you are willing to risk it...
    format then when you get home use Recuva (its free, search it on google!) to get your files back (but wont always work...)
    I recommend using backups.
  7. Ryan Piggott
    Oct 19, 2009
    54
    Folsom CA
    I had maybe 10 shots on the card. (Fine, small, if it matters for any reason).
    I took a picture of my dog or something, then i turned to take a picture of a watermelon and it wouldn't take the picutre. I took a look at the top display and it said "FORM". So i did it figuring if i lost the pictures it wouldn't really matter.
  8. Ryan Piggott
    Oct 19, 2009
    54
    Folsom CA
    When you say backups, are you referring to backup cards?
    I'll definitely check out that program, thanks
  9. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    Sorry, this is totally wrong.
    There is a warning but there is no way to "delete all your images" or "erase" the images.
    All that happens when memory is formatted is the sector headers are rewritten as unassigned and available for use again.
    If you make new images to the card, it writes the new image file info over the old image data that is still there. The images are still there but the header information no longer contains the info that defines the image parameters (size, color space, EXIF data, etc).
    Recovery software sorts through all the data on the card and any info that isn't header information is assumed to be image file data. Algorithms are then used to identify the beginning and ends of the image files.
    So Ryan,
    The FORM error is saying the card isn't formatted for use in that camera.
    You don't mention how old the card is, how long ago you took those few images, how you had previously formatted that card, (formatting it with your computer is not good. Always format it in the camera.), nor what brand of card it is.
    Each card maker usually has recovery software available on their web site.
  10. Ryan Piggott
    Oct 19, 2009
    54
    Folsom CA
    Thanks for the clarification.
    I did mention a few of the things though :mrgreen:
    The card is fairly new, I got it maybe 5 months ago. I took the few images over a time span of an hour up to the point where it gave the FORM error.
    I did format the card on the camera, using the two buttons simultaneously.
    Should my card not be doing this? Is it going bad?
    Thanks
  11. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    Yep, I missed some of that.
    How did you last format the card before you made the images you are wanting to try and recover.
    Also, I just noticed you're having other problems with your D70s. Have you looked closely at your battery contacts down inside the camera?
    I don't believe your camera is UDMA capable though your card is.
  12. Ryan Piggott
    Oct 19, 2009
    54
    Folsom CA
    A month ago i got a "CHR" (something like that, but it meant the card isn't compatible with the camera although ive never had a problem before that) error and then a "FORM" error right after. So i did the same thing, i held both format buttons on the camera. It then worked great until just now.
    I am not sure what UDMA means.
    Thanks for the help.
    edit: forgot about the battery thing.
    I did clean the contacts on both my batteries, but i not sure how i would clean the contacts deep in the battery slot on the body.
