i need your help, please
Discussion in 'Beyond the Basics' started by kimbie05, Jul 22, 2003.
  1. kimbie05
    kimbie05 TPF Noob!
    Jul 22, 2003
    53
    chicago
    i have a few questions that i could use some help on. first, what is the difference between c-41 and e-6 processing? second, what does it mean to "push process" film? third, what does film ISO mean? fourth, what is a panalure print? fifth, what is an internegative? and FINALLY, what is a full frame print? these are questions i cant seem to find the answer for and need help from some people who know these things. THANK YOU
  2. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    c41 - color negative process
    e6 - color transparency (slide) process
    push processing - typically used to develop pushed film. if you shoot a 200
    speed film at 400, the developing process must change.
    internegative - i do black and white work and i use internegatives for
    alternative processes that require contact negs. i simply expose a negative
    onto another negative which results in a positive image on a negative.
    panalure - paper made by kodak for printing color negs in black and white
    full frame print - a print that is 'full frame in' is one that hasn't been cropped.
    some folks actually print the sprocket holes as proof of full frame in.
  3. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    oops; forgot one.
    iso - iso, asa, and din are all film speed ratings. film speeds are based on the speed of reaction of the heel and toes of films. a lot of photographers rate their film at a different speed than is suggested on the box as they seem to be somewhat optimistic.
  4. kimbie05
    kimbie05 TPF Noob!
    Jul 22, 2003
    53
    chicago
    thank you SO MUCH. you have no idea how much you've helped me!
  5. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    you're very welcome.
    i might also add that there are black and white films that go through the c41 process.
    there's a lot more that can be added to each of the explanations above, but without knowing your particular application, would be too exhaustive to type.
