I think i may have broken my first ever camera!
Discussion in 'Photography Beginners' Forum' started by Andreal, Jun 1, 2007.
  1. Andreal
    Andreal TPF Noob!
    Jun 1, 2007
    60
    Hi everyone, I am brand new to photography (ie. I just finished reading the manual and that is the extent of my current knowledge). I was interested in getting into photography and a friend of mine suggested the Nikon D80 to start with, after doing a bit of online research and having a look at the camera in some store I decided that it was the one for me. However after a few weeks of owning it and playing with the settings to learn how it works and stuff, I fear I may have broken it!
    Now the problem is, the camera seems to be acting as if it has some sort of manual override. It will autofocus when the shutter release is held down half way, but if I then turn the autofocus ring it will manually change the focus. I have made sure that both lens and camera are set to autofocus and I have reset all the settings on the camera but this still happens. I am 90% sure that this camera didnt used to do this, I could autofocus, turn the dial and nothing would happen. Have a broken something, is it easily fixable, or was I wrong and is the camera functioning properly, anyone with a D80 know?
    Would really appreciate any help anyone can give, Im going crazy with worry!
  2. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    As far as I know (at least with Canons cameras) manually turning the focus ring will always change the focus. Now this could damage the lens if is it in auto focus unless it's one of Canons usm lens' which have manual focus override.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    What lens are you using?
  4. Andreal
    Andreal TPF Noob!
    Jun 1, 2007
    60
    Im using the 18-135mm lens that came with the camera. Sorry if this is too vague a description, im still really new to this.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    you didn't break it, its' supposed to do that. It's an AF-S lens, meaning instant manual focus override, just from touching the ring.
    It's good that it does that.
  6. Andreal
    Andreal TPF Noob!
    Jun 1, 2007
    60
    Oh thank god :D
    Thanks for all the helpful replies! I guess I just didn't notice it before :D
    BTW, just out of interest and my desire not to be so newb at this, what does AF-S mean? I cant seem to find it in the manual.
  7. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    If Nikon use a similar system to Canon then it means it's a digital only lens. The camera you have has a smaller sensor than a full 35mm negative. That means that the lens you have isn't actually 18-135 - you see through it as the equivalent of 28-215 (approx) assuming the crop factor is 1.6.
    A Nikon AF lens would fit almost every Nikon body - the AF-S is a digital only lens and will only fit Nikon digitals that aren't full frame.
    I believe I'm right in saying there isn't a Nikon full frame DSLR yet?????
  8. Andreal
    Andreal TPF Noob!
    Jun 1, 2007
    60
    Ah, thanx for the reply, although im still a little confused about the numbers 18-135 correlating to 28-215, i guess i can understand what you mean there about not having a full sized sensor, does it just get magnified in the camera to be the same size as a 35mm sensor? Also the numbers never really mean anything to me, I can understand thats a 18-200mm lens will have greater zoom ability than a 18-135mm lens but what do the numbers actually represent? I always find myself thinking will that be enough (I am thinking of buying a new lens so that I can experiment a bit more, hopefully this will help the learning process :p).
    Anyway, sorry for my ignorence on the subject, it seems like every answer spawns more questions :p. Hopefully I will be able to contribute back to these forums someday :D
  9. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Yes it is :wink:
    It's an 18-135mm. An 18-135mm lens gives a different field of view on an "APS"-sized sensor to a 35mm sensor. It would also give a different field of view on a medium format camera if it could be mounted to one. But it would still actually be an 18-135.
    The "equivalent" is only so people can compare with what they were used to with 35mm film cameras (or what they use on 35mm sensors). Otherwise it's meaningless. And the D80 is Andreal's "first ever camera", she presumable hasn't used a 35mm, so it won't mean much. You are right that Nikon doesn't have a full frame dSLR yet, nor do the other companies apart from Canon. Which is another reason why, unless you shoot Canon or remember 35mm film, the "equivalent" is pointless.
  10. Mike_E
    Jan 26, 2007
    5,327
    266
    Andreal, don't worry about crop factors or full frame anything just yet, just concentrate on getting the exposure right and the subjects in focus. Your best friend right now is the histogram! (look in your manual) Keep the right side of the body of the histogram as close as you can to the right line with out going over it. "The lines are our friends!"
    mike
  11. Andreal
    Andreal TPF Noob!
    Jun 1, 2007
    60
    Hi mike, thanks for the reply! I think I know what you mean (those RGB histograms you can view after the photo is taken?). Mine show the histogram with 3 vertical lines. Your saying i should keep the left withing the lfet line and the right withing the right line right? I looked at some of the photos I have and they are generally within these lines, but the all seem to have a massive spike to the VERY left of the histogram. I know from the manual that this is measuring the quantity of bright/dark pixels, but any idea why it would have such a massive spike at the beginning and what I can do to reduce the problem?
    PS. ZaphodB, im a guy, my name come from a spelling error my friend made that I thought was amusing and looked cool :p everyone seems to think it means Andrea L though and hence think im a girl, oh well, maybe I should stop making accounts with this name :p, thanks for the clarification on lenes and sensor sizes bte :D
  12. darich
    Jan 22, 2005
    1,230
    So are you agreeing, disagreeing or clarifying what i said??:)
