I want macro lens
Discussion in 'Photography Beginners' Forum' started by mfares, Dec 10, 2008.
  1. mfares
    mfares TPF Noob!
    Jan 5, 2008
    18
    Dear all
    i want to buy macro lens for my Canon 50D . but i dont know what is the best one to use .. can you guys tell me which one you think are the best to buy
  2. mfares
    mfares TPF Noob!
    Jan 5, 2008
    18
    By the way i put budget for this lens to be max 500$ ( i dont know if the price here in united arab emirates will be the same as other places but as i see the defrence not big)
  3. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I don't know the price on it but I have more often than not seen the Canon EF 100mm macro suggested.
  4. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    60mm ef-s maybe?
  5. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    A used Sigma 105MM F/2.8 That is if someone is willing to ship to the UAE.
  6. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I think the Canon 100mm f2.8 Macro fits your budget and it is an astounding lens. I'm not quite sure why it isn't an "L" series except that they forgot to paint a red stripe around it.
    [ame]http://www.amazon.com/Canon-EF-100mm-USM-Cameras/dp/B00004XOM3/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1228975682&sr=8-1[/ame]
  7. Warren_G
    Warren_G TPF Noob!
    Jun 18, 2008
    65
    Saskatoon, SK
    Amazing lens for portraits and macro work.
  8. Overread
    May 1, 2008
    23,947
    4,126
    UK - England
    Well your choices for a good macro lens are:
    Canon EFs 60mm macro
    Canon 100mm macro
    Tamron 90mm macro
    Sigma 70mm, 105mm, 150mm, 180mm macro
    All of the above are quality lenses and will deliver good sharp results - so getting any is a good move. The general rule is that you want to start off with a lens of around 100mm or longer to give you a decent distance from the camera to the insect (provided you are shooting bugs) so as not to spook the insect.
    After that consider that a longer focal length also helps with increaed background blur in a shot - often a desirable feature in macro shots.
    As for my advise as to which to choose its tricky - the Canon 100mm is certainly a quality lens and the workhorse of many a macro photography - bare in mind though that it ships without a lens hood or tripod collar and that these two (IMO essentail) components need to be bought separatly. The hood is important for blocking out unwanted light and also allowing defence against things hitting the front element of the lens - the collar helps a lot when shooting from a tripod with weight distribution.
    With both of those parts added to the price the cost of the 100mm raises to be almost the same as the sigma 150mm (which has both hood and collar included in the price)
    The sigma 150 and 180mm models are the top macros of the line for sigma - and well worth a look. Both (like the canon 100mm) are internally focusing (which means that physical lens length remains the same no matter what you set the focus to) and further they are also both compatabile with sigma teleconverters - I often find myself using a 1.4 teleconverter to get a little bit of extra magnification which is great when working with small bugs - a 2* teleconverter is a harder combo to use and is better suited to tripod shooting.
    Also the sigma 180mm is generally considered a to be a bit heavy for continued handheld use - whilst all the rest are fine for handheld work.
    Note also that whilst the EF-S 60mm is very fine lens it is crop camera body only - if you want ot move to a fullframe body later this lens will not work with such a body
    Hope that helps
  9. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    Just a couple of thoughts --
    Although I have tripod collars for my tele lenses, I don't use one with my 100mm -- I don't find any real disadvantage to not using the collar as the lens is relatively small. You can buy a cheap hood if you don't want to spend the money on the Canon.
    The 100mm is a beautiful portrait lens.
    I think the 60mm Canon is an EF-S, so not good if you get a full frame camera -- the 100mm works fine with both crop and full frame.
    Ian
