If I?
Discussion in 'Beyond the Basics' started by Ihaveaquestion, Apr 1, 2005.
  1. Ihaveaquestion
    Ihaveaquestion TPF Noob!
    Mar 31, 2005
    289
    San Francisco
    If I bought the Nikon N80 would the lens I bought also work on the nikon D70 digital camera?
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Yes
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Oh, but the focal length will alter by a factor of something (1.5x?). I'm no digital expert, but I'm sure someone will know exactly how much difference and any aberation which may occur as a result?
  4. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Yes, that sounds right. The D70 has a digital sensor that is smaller than 35mm film, so the sensor only sees part of the image projected into the camera by the lens. The result is a crop factor (1.5 for the D70, I think). That means that a 50mm lens on the D70 will give you the same field of view as a 75mm lens on a film camera.
  5. Andrea K
    Andrea K TPF Noob!
    Dec 16, 2004
    2,025
    28
    Philadelphia/North Carolina
    1.5x for the d70 is correct
  6. Ihaveaquestion
    Mar 31, 2005
    289
    San Francisco
    So you'll see more in the lens than is actually on the picture your taking.
    Huh.,
    Is it kinda tricky to get used to?
  7. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    No, you don't actually see any more than the sensor sees because of the way the mirror and viewfinder are set up.
    No, in fact you might not even notice. The lenses will work on either camera just fine. The difference is really only noticeable if you were looking at a scene with the lens on a film camera, and then put the same lens onto the digital camera. You would see less of the scene with the digital. That's it.
    If you stick to one camera, what you see is that you shoot. Simple as that.
  8. Ihaveaquestion
    Mar 31, 2005
    289
    San Francisco
    Word!
    Thanks guys :afro:
