Ilford Delta-3200 Professional
Discussion in 'Beyond the Basics' started by Bauhaus, Aug 25, 2004.
  1. Bauhaus
    Bauhaus TPF Noob!
    Jan 29, 2004
    38
    Nor*Cal
    Can this film be devloped with the color chemicals?
    Delta-3200 Professional 120 Black & White Print Film (ISO-3200 Push Process)
  2. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Why would you want to do that? :?
  3. Galaxy_Stranger
    Galaxy_Stranger TPF Noob!
    Apr 21, 2004
    99
    Houston
    Developed or Printed?
    I've seen people experiment with printing black and white film with color chemicals to produce some interesting results.
  4. Scurra
    Scurra TPF Noob!
    Aug 19, 2004
    1,159
    7
    Kent UK
    I have a couple of rolls of ilford that I have been told can be developed using colour chemicals to give a sepia effect or just developed in the standard b&w method.....
  5. Bauhaus
    Bauhaus TPF Noob!
    Jan 29, 2004
    38
    Nor*Cal
    See I dont understand this C41 process vs real b&w process.
  6. green
    green TPF Noob!
    Jul 16, 2004
    135
    if it says it can be developed as a C41 process, then yes... if it doesn't... back away slowly, and get your sepia effect using toner. no sense risking your pictures. I've never known a film to be an either/or situation...
  7. Scurra
    Scurra TPF Noob!
    Aug 19, 2004
    1,159
    7
    Kent UK
    The film that I was quoted to be either or is.....
    *Scurra runs off to his film stash to check*
    Ilford super XP2 ISO 400, it does say on the packaging however that it is good to use with C41.
  8. Bob_McBob
    Bob_McBob TPF Noob!
    Jul 28, 2003
    160
    Ontario, Canada
    Running black and white film through the C-41 process will result in completely clear film, as the silver is all bleached off. (i.e., don't do this)
  9. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    I know of no films that are intended as either/or for processing. There are B&W films that develop in traditional B&W chemicals, and there are B&W films that use the C41 color developing chemicals (like T400CN and XP2). With fewer and fewer labs doing traditional B&W developing, film companies came out with a way for people to take B&W pictures using easily an accessible process.
    If it says C41, use color processing. If it doesn't, use traditional B&W processing.
