I'm a newbie with issues.
Discussion in 'Photography Beginners' Forum' started by SaraShanae, Nov 23, 2007.
  1. SaraShanae
    SaraShanae TPF Noob!
    Nov 23, 2007
    South West Michigan
    hi everyone!
    So heres my problem.
    Ive got roughly $1200 to spend on good lenses for my new 10.1 canon rebel xti.
    i have two lenses already, one is a tamron 28-80mm and can i just say- VERY disappointed.
    i need two different types- one for close close shots to like 5 feet or so away.
    and then one for further away
    I'm s using this camera to shoot senior portraits, baby announcements, engagement pictures and eventually weddings
    I've just got into photography and tho i'm still learning about cameras and whats what, I got into it because I'm awesome at photoshopcs3 and other software.
    what i would like to do, however tho, is to take pictures with a quality camera and lens that will require minimum editing.
    Suggestions?
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Canon 70-200mm 4.0L and a Canon 100mm Macro.
    Should be right around your budget, and can get close up and far away.
    Unless you wanted a wide angle for close...I'm not sure whether you meant that. Then maybe a 35mm...I dono.
  3. SaraShanae
    Nov 23, 2007
    South West Michigan
    nope ive got a wide angle macro thats attachable :)
    thanks!
  4. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Man, that doesn't really sound like a problem. $1200 to shop. Hmmmm. Lets see. The 2 lenses sideburns mentioned are great. I would stretch your budget to a 50 f/1.8 and 85 f/1.8 over the 100 f/2.8 macro. Two for one. Can't go wrong with the 70-200 f/4 L. It is a superb lens for the price. If you want to improve your general zoom lens, than look at the better lenses in that range. Unfortunately, quality=$$$$. The best glass has an "L" attached to the end of it in most cases. Standard protrait, wedding lenses of superb quality are the EF 24-70 f/2.8 L, 70-200 f/2.8 L IS, EF-S 17-55 f/2.8 IS. EF 24-105 f/4 L IS, EF 16-35 f/2.8 L, EF 17-40 f/4 L. Prepare for sticker shock. All photos will require some degree of post-processing but the out-of-camera quality of these lenses leave little to be desired.
