i read many articles and posts on the internet but i still had some questions that i wanted to ask.
basically.. i work a lot by the coast where it is often windy. my biggest fear is my tripod will just tip off in the middle of the beach
Make sure you get one with an anchor point then. It looks like a hook that hangs in the middle of the tripod below the head in between the legs. Then invest in a sand bag or make one that will work for your purposes
Get a tripod that can extend the legs out to more than one position. Mine has three - all the way out the tripod is almost flat on the ground. Extending them to the middle position adds a ton of stability.
Anchor point is good too, like Mgw189 said. It can also usually be used to attach a carrying strap.
Bogen/Manfrotto tripods - a few to pick from in your price range.
I haven't used most of those before. It looks like the only reason that they're so cheap is that most of them have non-removable heads.
Edit
You'll probably be pretty safe with any Bogen/Manfrotto tripod. Just pay attention to the weight capacity.
oh wow, i haven't seen a bogen/manfrotto that cheap, until you just showed me of course
