I'm starting to hate my macro mode
Discussion in 'Photography Beginners' Forum' started by helloyo53, Sep 10, 2009.
  1. helloyo53
    helloyo53 TPF Noob!
    Feb 28, 2009
    77
    Sarnia Ontario, Canada
    This is really starting to get on my nerves. I have been trying to take some macro shots for the past two days now and I can't get my camera to focus properly. I am using the super macro mode on my Fujifilm Finepix S1000fd, and everytime I try to focus the stupid thing won't focus and it will come up AF! and it's really starting to get on my nerves. I am also tried using aperture priority and setting it to 6.4, and that doesn't make a difference. What the heck am I doing wrong, I really like macro photography, but this is starting to get me mad.
    If you want to see my failed macro pictures just go to my newish thread in the Macro section called "Flowers in my Backyard" and you can see how crappy they turned out.
    Thanks for any help.
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I think that with most digi-cams, once you put them into macro mode, your focus range becomes limited to short range. So for example, when you are in 'super macro mode', you might only be able to focus on things that are 4cm to 10cm away. If you are closer or farther away, it might not be able to focus.
    Just a thought.
  3. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    How close are you holding the camera to the subject? If you're too close to begin with, it won't be able to focus properly. I don't know the specific minimum length that yours will be able to focus but you should be able to find that in the manual. I'd also say to stay away from the auto modes.
  4. helloyo53
    helloyo53 TPF Noob!
    Feb 28, 2009
    77
    On the super macro mode when I first go onto it it says "Close up shots up to 2cm, but when I go 2cm, it won't focus, and I keep moving further away until it focuses, and then it is so far away it just takes away from the macro point. Friggin annoying....
  5. Overread
    May 1, 2008
    24,063
    4,171
    UK - England
    Hmm does your camera have a manual focusing mode built into it? You might find that easier to work with for your close ups. Also make certain your using a tripod = most of the digicams don't like macro mode shot on anything but a tripod since shake becomes a real problem (and will contribute to softer shots).
    As for manual mode apertures you want the greatest depth of field you can so your wanting to use the smaller apertures (which means the bigger f numbers like f6.4) If your on a tripod though do remember that whilst the camera is now still the subject might not be (wind) so do consider keeping the flash out to let your shutter speed say high enough so as to counter the wind effect.
  6. ErectedGryphon
    ErectedGryphon TPF Noob!
    Sep 9, 2009
    333
    Houston, TX
    Keep in mind it's a point and shoot with a non-removable lens. This will limit the actual macro capability since it is primarily designed to take pictures of people in places of interest. I would not expect it to operate as well as a true macro lens, though there are a few companies that make macro filters to increase the capabilities of point and click macro. This is where Google will come in handy.
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Actually, macro is one area where many 'digi-cams' do quite well...compared to a DSLR with a typical kit lens. Many of them can focus on objects very close, some down to an inch or less. That's something that a regular SLR lens can't do.
  8. ErectedGryphon
    Sep 9, 2009
    333
    Houston, TX
  9. helloyo53
    helloyo53 TPF Noob!
    Feb 28, 2009
    77
    I'm hoping for Christmas that I will get a camera with different lenses. Since I am only 13 money isn't too easy to come by, especially when it comes to like $1000. So I hope I can get a camera with detachable lenses for Christmas.
  10. helloyo53
    helloyo53 TPF Noob!
    Feb 28, 2009
    77
    This is what bugs me too, it used to take great macro pictures, look at this picture I took:
    [​IMG]
    I just don't get it...
  11. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Of course not. You have a focusing problem. The aperture doesn't control the focus distance.
    Perhaps you failed to read the specifications for the camera completely. The camera will focus to 5cm/2" in the Macro mode, but only when zoomed to its widest setting. When zoomed to full telephoto, the minimum focusing distance in marcro mode is 80cm/2.6ft. The only time it can focus to 2cm/0.8" is when it is in the "Super Macro" mode instead of "Macro".
    Fuji's specs:
    FUJIFILM USA | FinePix S1000fd : Specifications
  12. Error
    Error TPF Noob!
    Jul 6, 2009
    75
