RyanLilly
- Joined
- Aug 27, 2007
- Messages
- 1,489
- Reaction score
- 10
- Location
- St. Louis, Missouri, USofA
- Can others edit my Photos
- Photos NOT OK to edit
So, I'm planning on buying the Noiseware plugin, but I have a few questions.
First Is it worth getting the Pro version because it will work with 16-bit images, or because I'm saving to 8-bit jpegs, will the standard version be fine as long as its the last thing I do before saving. That brings me to my next question, If I need to interpolate an image for a bigger print, Obviously using a 16-bit file is going to give the best results, but should I use noiseware before or after interpolating a image. Which will probably determine weather I get the 8 or 16 bit version.
Thanks, Ryan
Thanks, Ryan
