Improvements to a manually produced panoramic
Discussion in 'Photography Beginners' Forum' started by bazpaul, Nov 20, 2009.
  1. bazpaul
    bazpaul TPF Noob!
    Sep 7, 2009
    53
    Australia
    Hi, guys i took this pan from a cliff so there was nothin much i could put in the foreground which thus makes the pic a lot less appealing. But i had to make the panoramic myself as CS4 just couldnt piece it together.
    Anyway does it look right to you??? what changes and imrpovements can i make? In cs4 i added saturation (blue/red), curves, upped contrast, duplicated the background and blurred the sky ever so slightly, then masked in the sea.
    Should i use the rule of thirds and get rid of most of the sea, so it only make up a third of the vertical??
    Im lost with this image, i dont know where to take it!!! It was such a beautiful sunrise but i just cant capture it in this photo!!
    Any advice would be great cheers!!!
    [​IMG]
  2. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Just looks like one of those peaceful sunset shots to me. You may consider cropping to give 1/3 to either the ocean(?) or the sky, but otherwise it looks fine to me.
  3. battletone
    battletone TPF Noob!
    Sep 22, 2009
    285
    Somewhere in the lower 48.
    I like it cut in half like it is. I don't think 1/3 would work better with this.
    The only thing that bothers me is on the right there seems to be a triangle of darker blue coming in from the side that doesn't feel natural. Is that where you were cloning?
    But to nit pick, there are a few areas I can see where the images are coming together. If you have enough overlapping, I like to mask it with a soft edge brush in a sort of "snake" like path. I just feel it interweaves the two layers much smoother.
  4. bazpaul
    bazpaul TPF Noob!
    Sep 7, 2009
    53
    Australia
    yeh i think i will crop it....to much water!! but to have at least a small bit of land in the bottom right corner was important i thought!!!
  5. bazpaul
    bazpaul TPF Noob!
    Sep 7, 2009
    53
    Australia
    yeh i dont know what to do with this?? its how the image was shot....its just the way the light came in to the lens.
    and yes i did use masks and should really try the snake motion you talk about!!
    i wondering if people can spot the seams!!
  6. Layspeed
    Layspeed TPF Noob!
    Oct 11, 2009
    307
    British Columbia, California & Philippines
    I agree with astrostu, I would crop out some of the ocean? And that blue triangle shape could maybe be cloned out? Not that I know anything about cloning though :lol:
  7. KmH
    Apr 9, 2009
    40,751
    5,588
    Iowa
    Certainly, all of the composition rules can be broken...if you have a good reason.
    That said, the one compositional guideline to break least often, if you want dynamic images.....is the Rule-Of-Thirds.
