snakeman55
11 feet, 60 pounds
Thanks
Thanks
Welcome to the forum, is that your snake?
Exactly. It is the handiwork of a wide open aperture.GARRETTgalbreath said:Wow nice pic. How do you capture the foreground as clear and the background blurry? I've always wanted to do some shots like that, but can't figure it out for the life of me. I'm using a digital camera if it makes a difference. Something with aperture right?
You can also get this effect by using a long lens, correct?It is the handiwork of a wide open aperture.
The aperture numbers of a good long lens usually starts at 2.8. I wouldn't know for sure if f2.8 would give you the shallow 'depth of field ' in the above picture.Nicodemus said:You can also get this effect by using a long lens, correct?
You can't buy new lens for the DSC-V1. It is a fixed lens camera. However, its Aperture ranges from 2.8 to 4.0. Read the booklet that came with the camera. See if you can manually change its aperture. If yes, select a subject, and shoot a bunch of frames with all the aperture values (2.8 to 4.0). Just make sure you do not change the focal length (zoom) or move while doing this test. You will see the 'effect' varying.GARRETTgalbreath said:I have a Sony Cybershot 5mp DSC-V1. Is a new lens the only/best way to get the DoF in order to take photos like that? I'm not planning on buying anything for this camera, I'm really new to this and just trying to learn some fundamentals and decide which way I want to head into photography.
