inexpensive lighting setup?
Discussion in 'Photography Equipment & Products' started by jackfrost, Dec 12, 2006.
  1. jackfrost
    jackfrost TPF Noob!
    Jan 29, 2005
    22
    dayton, oh
    I started doing some photo work for my wife's bakery business. you can check out what i've got so far at her website:
    http://www.getsweetnothings.com
    Basically what I'm doing is putting the food on a white sheet in the dining room, and crowding as many lights around as possible. I set my Rebel XT into portrait mode with no flash. it seems to be working okay, but I am thinking that some extra studio-style lighting might help, and be easier to set up.
    here are the caveats: i am pretty much a n00b, and haven't done any post-processing of the images on the site. her business isn't making money yet, and I don't have much disposable income, so options must be cheap, or may consist of "creative construction". i am handy. ;)
    thanks for the input.
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The shots look OK...but they need some post processing. The white balance seems to be a bit off...and they look a bit under exposed. (the whites are not white)
    Shoot in RAW mode...that will allow you to change the WB after the shot, in the computer. It also give you more leeway with exposure.
    If you really want some studio type lighting...I suggest buying or building a light tent. It's basically a tent made of white translucent fabric. Then you can use lamps or whatever to light up the outside of the tent. Then light inside will be nice and soft.
  3. niccig
    niccig TPF Noob!
    Jun 4, 2006
    276
    Lexington, KY
    I made my own light tent and it's worked out pretty well. My "studio" lights are clip-on work lights from home depot, with a couple of bed sheets thrown over the whole setup. Here's a link to the instructions I used:
    http://www.photographica.org/story/2006/3/4/18452/50682
  4. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    The shots are good, in my opinion, but the whites need to be WHITER... so I would do that in post.
    Download "PICASA 2" from google. Its easy to use for noobies, me too, and you can get some AMAZING results... seriously.
    Look at this pic of mine:
    [​IMG]
    The lighting was ONE walmart floorlamp, and I intentionally burnt the background (a fuzzy white blanket) and overexposed it in Picasa 2.
  5. kemplefan
    kemplefan TPF Noob!
    Jan 24, 2006
    297
    Baltimore maryland
    thos epicturs on the website are not that bad, atleast i have seen worst, my photography solution to most things is try it, its digital, trian and eror is the best way to learn (ususaly)
  6. basil_chiu
    basil_chiu TPF Noob!
    Jan 3, 2007
    11
    Eastern Ontario
    I think technically, your shots are good; it's probably time to start thinking about artistry. Have you considered using focus, lighting and depth of field to focus on one cookie, for example? Instead of using the portrait mode, I would simply crank the aperature as wide as possible, move in closer (to eliminate as much background as possible) and focus on a the closest cookie. This gives the impression of a field of cookies, which implies your wife's business is full of cookies.
