Inexpensive Telephoto Lens
Discussion in 'Photography Beginners' Forum' started by smudger, Jan 2, 2007.
  1. smudger
    smudger TPF Noob!
    Jan 2, 2007
    6
    I have a Canon Digital Rebel XT and am a REAL AMATUER to photography. I am looking for a telephoto lens I can buy, that I can use to photograph my kids while playing sports. Is there an inexpensive (below $150 perhaps) lens out there that is worth purchasing. Keep in mind I am an amatuer, so I am not looking for anything ground-breaking.
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    generally speaking fast telephoto lenses are always expensive.
    but you can try to get a used Canon 70-300 at ebay or some off-brand lens from ebay. however you will encounter at least a certain
    amount of frustration as the lens will sometimes/often be too slow for sports.
    even for pros sports photography is one of the most expensive segments in terms of lenses.
    my advice, get the best lens you can for your budget, and get a used one. I would not go beyond 300mm as then camera shake will be a severe issue if you don't use a sturdy tripod.
    Mybe even 100mm is enough, depending on the sports your kids do ...
  3. CMan
    CMan TPF Noob!
    Nov 6, 2006
    309
    Indiana
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Welcome to the forum.
    The typical telephoto zoom lenses in the lower price range are the 75-300 lenses. Canon makes (or has made) several different models. Sigma and Tamron also make similar lenses that will fit your camera. $150 may be a little low to get one new...but maybe a used one could be found to fit your budget.
    As mentioned, the problem with these lenses is that they are slow...by slow, I mean that they have a small maximum aperture. This means that unless the lighting is quite bright, you would have a hard time getting fast shutter speeds...which are essential to freeze action shots.
    You could still use a lens like this to shoot your kids during sports...but you will need to work on getting the shots when they aren't moving too much. Like a stop in the play or even at the top of a jump. It's not a perfect way to work...but to get shots like you see in sports illustrated, or even in the sports section of the newspaper...you might need a lens that costs 5 times as much as your camera.
  5. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    the 75-300 F4-5.6 Sigma i have only cost $120 + shipping on Amazon. after using it, and then borrowing the Canon 100-300 and using that for a couple shots, i can honestly say i did notice a slight difference between the 2, but for me it wasnt worth spending $300+ more for the Canon. im positive others will disagree, but this is just my opinion. i cant afford to spend even $300 on a lens unless i save for a few months so for me, for now, the Sigma is fine. when i can afford to put some money away, i will be looking to replace it with a Canon lens though. the Canon was a little bit better, and i think it felt like it was better made.
  6. t_rust
    t_rust TPF Noob!
    Dec 18, 2006
    6
    You will need to spend at least 500$ for a decent telephoto lens.
    Look at[FONT=Verdana,Arial,Helvetica,sans-serif] EF 70-300mm f/4-5.6 IS USM.
    If you need more reach than it gets really pricey. Check the [/FONT]
    [FONT=Verdana,Arial,Helvetica,sans-serif]EF 400mm f/5.6L USM (no zoom).
    Regards,
    Thorsten
    http://tr-photo-blog.blogspot.com
    [/FONT]
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I do not reccommend anything beyond 300mm for a beginner.
    And L glass is no option here at all I am sure.
  8. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I have a Tamron 70-300mm f/4-5.6 that I bought early on. I was just wanting something to play with and for under $150 I think I got my money's worth. You can find them on ebay for probably 129. Look for a seller by the name of cameta auctions. This lens got surprisingly good reviews even though it is cheap. Takes a good enough picture though. It's rather light as well since the construction is largely plastic.
  9. Tyson
    Tyson TPF Noob!
    Nov 19, 2006
    652
    Newark Ohio
    I got my E-500 for one heck of a deal from cameta camera. If it wernt for them I would not have a DSLR. You can get to them on eday and at www.cameta.com . I highly recomend them, I am getting ready to but a lens from them it is a 40x180 I think, it has a buy it now for like 99 or 120 bucks. Its an olympus brand kit lens I think.
  10. gundy74
    gundy74 TPF Noob!
    Jun 12, 2006
    56
    Pennsylvania, USA
    ill admit i know squat about canon but i got a 70-300mm lens for my Nikon for $120 at BHP so canon probably has something to compete with that price. its not a pro lens but it gets the job done
    is it just me or does canon have more lenses than nikon?
  11. smudger
    smudger TPF Noob!
    Jan 2, 2007
    6
    Thanks for everyones suggestion. Another NEWBIE question, with these 75-300mm lenses, what do I need to be looking for in terms of filters (e.g. size, drop-in, etc.)? I really just want a UV protection filter at this time. Cheers.
  12. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I doubt it. Actually, Nikon probably has more lenses for their current cameras because their compatibility goes back to the 60s or 70s. Canon switched lens formats with the EOS system in 1988.
    If you want a UV filter for protection, then get one...but personally, I wouldn't worry about it. You would be better off getting a plastic lens hood...which will protect the lens somewhat and also give much needed shading to the lens. The most used/needed filter, especially for digital is a circular polarizer...however, with these consumer telephoto lenses...it's a struggle to get usable shutter speeds...and a polarizer will make the problem worse. My suggestion would be to forget about a filter and get a hood.
